Question about Video Cameras
Panasonic m7 vhs video camera while in play mode camera stopped and made whiring noise then shuts right down will not eject how do you get tape door open manually
  • 172 Answers
Hi, open eject door,try to see very small lever at the left side cassette at lower end and try to pull it at your side with very thin and at least 4 inch long screw driver.Cassette compartment will open. But its not so easy to find.It need patience.
Posted on Aug 10, 2010
  • mcculchris_1 Jul 09, 2011
    what color is the lever i cant find it i am having the same problem and dont want to force it out
6ya staff
SOURCE:
I cant open the door to eject or put in a tape..
Shut it off, remove battery, install battery , turn it on and try it again, usually it works.
Mar 31, 2016 | Panasonic Palmcorder PV-D209 - camcorder -...
Panasonic M7 VHS Camera
1.) set your pc to the correct norm (PAL or NTSC).
2.) if this doesn't help maybe you need to clean the head of your camera.
Take a short search on YouTube how to do it, there are dozens.
(NOTE: if you have recorded something with a dirty head you will not be able to play it back correctly even if after your head is clean!!!)
Mar 08, 2014 | Video Cameras
Shuts off when trying to play or record
This could be due to the VHS tape sticking on the tape reel, that triggers the overload and the shutdown. Try fast forwarding if possible.
Nov 01, 2017 | Emerson EV787 VHS VCR
I have a Panasonic VCR (DMR-ES35V) and when you insert the tape, it does not thread the tape across the video head. The tape runs for a moment and then ejects.
There's either damage in the drive section, or more likely and in some cases "plus" the Mode Switch is set in the wrong position or is faulty. The mode switch tells the electronics what position the VCR mechanism is in. Such as play or fast-forward. If in the wrong place it will carry out other functions - such as eject - in your case.
Sep 27, 2013 | Panasonic PV-V4022 VHS VCR
The DVD part of the machine keeps skipping and now just won't play any DVD's.
I push the VHS Cartridge in, it drops down to the play position, the front door opens, the tape comes out, it goes around the chrome wheel that is spinning, but it will not play, will not rewind, will not fast forward. It then shows "Error" and the machine shuts off, with the tape still around the chrome wheel, When I turn the machine back on, the VHS Cartridge ejects from the machine. This machine has been used very little, I loaned it to my Son In Law and it came back with the VHS Tape Deck not playing. I have the machine open, so I can see what it is doing.
Dec 11, 2010 | GoVideo Go Video DVD/VCR Combo
Panasonic VHS Won't eject Tape
unplug then remove the top cover press down on the cassette release and remove the tape then rewind the part of the tape still sticking out by hand push in the button on the side of the cassette to open the cassette cover
May 21, 2009 | Panasonic PV-7400 VHS VCR
Panasonic Palmcorder PV-43D cannot get door open
Hi there.
Sometimes a gentle slap with the palm of your hand with the door facing towards the ground does the trick, make sure you power it off then on press eject while you gently slap it.
Good luck and thanks for using FixYa!!
Apr 21, 2009 | Panasonic Palmcorder VDR-M50 DVD Camcorder
CAMCORDER GR-DVL167EK
YOUR TAPE MAY BE DAMAGED IF YOU TRY TO OPEN THE CAMCORDER - HOLD EJECT BUTTON DOWN BEFORE ! YOU REATTACH BATTERY THEN READ THE ERROR CODE ? IF IT STILL DOES NOT EJECT .
Sep 10, 2007 | Video Cameras
Used a wet VHS cleaner and now my VCR doesn't work right. Help!!
The VHS cleaning cassette possibly deposited fiber in the heads in the drum. You may need to open the cabin and examine the heads and the mechanism for foreign matterial.
Feb 02, 2007 | Proscan PSVR72 VHS VCR
Tape Won't Load
something is blocking the mechanism and not letting it load or the mode switch is bad and the mechanism dosent know where it is. These camcorders are common for this type of problem and these days Im sorry to say that most places charge an arm and a leg just to look at them. good Luck
May 25, 2006 | Samsung VP-L700U Camcorder
Video Cameras Logo
799 people viewed this question
Top Video Cameras Experts
Al Rush
Ekse
Marvin
Marvin
Are you a Video Camera Expert? Answer questions, earn points and help others
