They are supposed to be self installing. If they are not ,its not your fault ,it means either they are faulty or your ports are. On my computer left click and select MANAGE THEN GO TO ports AND IDENTIFY YOUR PORT AS 1 OR11. Good luck
finding your Key Code For COD4 running Windows operating systems and playing COD4 to find your CD Key.
Fix:First Click on “Start” then “Run” In the “Open” field enter “Regedit” and click on “OK” Windows Registry Editor will open. Expand in this order: “My Computer”, “HKEY_LOCAL_MACHINE”, “SOFTWARE”, “Activision”, and finally select “Call of Duty 4′ on the right side you will see “codkey”.
To have the CD key for Call of Duty 4, just type the keywords "Call of Duty 4 serial key" and make a google search. This should give you many a links consisting your queries. Or you may simply try this one first:
DL2J-8PY4-4Q22-GE48-88D2 and see if this works.
Each CD has a specific CD key to avoid making copies of it to sell it to others. This means each CD can only be installed once.
Your options:
- Get the original version of your copy, uninstall this on the PC it is used on, and install it on the PC you like with the CD key (the CD key can be found inside the box or on the backside of the manual).
- The second option is to just make sure the original version is uninstalled wherever it was installed on, so you can use the original CD key (if you have it) to install it.
Otherwise I am afraid you cannot do anything with a copy of the game, and you will need a new CD key, but that is only gettable by buying a new game (original). The goal of a CD key is to avoid having people making copies, and that is what I think happened to you.
Please make sure you have the current patches installed before you install the Add-on maps. Unfortunately there is little support fro Add-on maps, I suggest going http://www.cod4forums.com/ .. registering, and posting there for help. I'm sure you will find the solution to the problem there!
Hi, firstly u hav to register yourself as register user with the help of CALL OF DUTY 4 using multiplayer option.Then you can pla it. Thanks & dont forget to rate me.
When this happens, you need to go to your dashboard because you arent even connected to xbox live. Then, log out and check your xbox live connection. One of the tests will fail and this will be your problem.
