Please put off your tv and open the back side of the TV. Look for dirt on the back side of the CRT that is causing the arcing of the high voltage. So when the high voltage is sparking against the ground section the lines are coming to the screen. So use a good dry cloth to clean and wipe clean.Use a good solvent like methy spirit to clean. Check to trial and repeat if the fault is repeating. Make sure the HT lines are not touching but keep them apart to redduce the sparks. Hope this will get the TV right. Good day
