Computers & Internet Logo
Posted on Aug 10, 2010
DVD driver is corrupt and can not access my DVD
Anonymous
Level 1:
New Friend:
  • Contributor 1 Answer
  • Posted on Jun 06, 2011
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
507
Points
(Windows 7 CD-ROM Drive & Mitsumi CD-ROM Drive)Windows cannot load the device driver for this hardware. The driver may be corrupted or missing. (Code 39)
Anonymous
Level 1:
New Friend:
  • Contributor 2 Answers
  • Posted on Aug 11, 2010
Anonymous
Contributor
Level 1:
New Friend:
Answers
Questions
Helped
1089
Points
Did you try rolling back the driver and then reinstalling from a freshly downloaded copy? If you can't rollback, uninstall the device in Device Manager and reboot. That should force it to reload drivers and might correct a corrupted driver.
Corrupted CD/DVDROM driver
Please explain your problem as corrupted cd/dvd rom driver doesn't stand for anything.
CD/DVD ROM driver can never corrupt only lens of cd/dvd driver becomes weak because of which it cann't read cd or dvd
Thank you for using fixya.
Hi my name is kishan i have trouble in accessing my cd/dvd drive.It can't read any cd or dvd. when i checked the properties it showed an error massage.The massage was showig an error code 39 and says...
hello
  • re-install your driver cd again..
  • The Acer product they gave you the driver cd check it and install the driver properly definetly it works...
  • Your statement gives code 39 error message ..
  • so that drivers problem only.. check it..
  • re-install it...
  • If it's useful for you means plz rate me the 4 Thumbs ....
D drive is my CD writer drive. when I try to access the D drive I get the following message. D:\ is not accessable. The drive is not ready
make sure that the cd burner is getting enough power test all leads that are attached to the dvd burner including electical extensions and make sure they have a secure connection or just replace them there might be bad/faulty or
your drivers may have been corrupted or you might have a virus run your antivrus program
you might have to physically unplug the leads for this cd/dvd burner then plug them back in or
you might have to uninstall then reinstall your DVD/CD or uninstall the driver then reinstall for this device
control panel admistrive tools,computer management,device manager scroll down cd dvd rom drives right click you can you can update driver,roll back driver,or select properties general troubleshoot, select driver click to reinstall drivers click update driver or uninstall then reinstall
hope this helps
The dvd drive (nec dv-5800a) corrupt driver?
Try going to device manager, and uninstall the optical drive. Reboot the comp . It should resolve the issue.
Device- SONY CD-RW CRX320EE It is detected by the OS(Xp-64bit). Device Status- working properly. Disks(any type) when inserted not detected . More over i can access the drive when i double click it even...
make sure it is not a DVD disk you are trying to insert into your Drive because your Drive is a CD-RW will not read DVD nor burn onto it.
Your disk may be damaged or corrupt and the drive cannot read it.
your drive may need a firmware update from Sony.
use this link below to access Sony's website to download drivers.
here is the link:
http://sony.storagesupport.com/
Driver is corrupted or missing?
Go to Dell website, check your model and download the Driver from there, reinstall it and check if it works.
I’m happy to help further over the phone at https://www.6ya.com/expert/mustafa_06f84c65ab5cc745
Drivers
1. Go to Start, Control Panel, System, System, Properties. Then click update driver settings.
Or, go to
2. WindowsXP.OfficialDrivers.net
They will scan what drivers are corrupted and repair them.
Hughie.
DVD Disc in my Toshiba Laptop Corrupted
make uninstall driver for CDW/DVD then re-boot.
Install the driver for CDW/DVD and use. It will fix your problem.
Thanks
Iqbal
Nn Harware configurrations
Your DVD rom driver is not working, now you reinstall the driver of the rom if possible then you can access the dvd rom.
Thanks
Top Fujitsu Siemens Computers & Internet Experts
ExpressFiX
ExpressFiX
Grand Canyon Tech
Grand Canyon Tech
Rob Hill
Rob Hill
Are you a Fujitsu Siemens Computer and Internet Expert? Answer questions, earn points and help others
