Question about Cooper Industries Weller Soldering Iron, Slim, for WES51, Uses Eta Tips
I have two WU81 Weller soldering irons and their are both showing the same fault. When we turn the irons on in the morning, the 500mA fuse that can be found in the base unit is blowing. Is this a common fault with this type of iron?
Posted by martin594 on
EugenesDIYDen
    Guru:
  • 479 Answers
Perhaps this fuse should be a "T" type or delayed acting (antisurge fuse) . If the fuse has been replaced by an "F" fast acting fuse then this could explain why they are blowing.
Posted on Feb 14, 2011
Cold iron
if under warranty - return it
Apr 19, 2014 | Weller HEW100P - Heater Assembly for W100P...
Weller WES51 does not heat up unless I turn to 700 degrees or higher
You may have a broken wire in the temp sensor in the tip of the iron or near where the iron connects to the base.
Jan 24, 2014 | Weller WES51 SOLDERING STATION
NEED MANUAL FOR Weller soldering station WESD51 POWER UNIT
You can download the manual from here: http://www.weller-toolsus.com/MagentoShare/media/mannuals/WES51_OI_PL.pdf
Jan 19, 2010 | Weller WES51 SOLDERING STATION
Repair wiring on weller soldering iron model ec1002
If the coil wire is snaped then you will need to replace all the coil. usually the power from the outlet goes stright to the coil and connects to both ends of it's windings
Mar 27, 2009 | Cooper Industries Weller Field Soldering...
Cooper Industries Weller Soldering Iron, Slim, for WES51, Uses Eta Tips Logo
164 people viewed this question
Top Cooper Welding Tools Experts
Bill Boyd
ray gallant
Are you a Cooper Welding Tool Expert? Answer questions, earn points and help others
