This could be that the drain tank at thebottom of the fridge is overflowing. Normally the drain water will evaporate off with the heat from the compressor but if possible it is good to clean and drain the collecting tray in the bottom of the fridge. You must have access to the backside of the fridge and remove the tray which is normally a pulllout. Drain , clean and put it back-- slide it in. Hope you do thei. Also make sure that the freezer setings are normal and not set high. During cold season this can condense more water to overflow the drain. Hope you try., Good day
