As you had done switch off the fridge. now after the frost had cleared off , keeping the fridge a little away from the wall switch on. But only after you have checked for the thermostat to be set to normal, the fan working fine as well as the timer switching on the auto defrost. So look out for the compressor to shut off when the thermostat reaches the limit, if this wont work then the ocmpressor will run and result in heavy frost. so it can be that the wires to the thermocouple is broken or damages due to frost. so you can open freezer compartment and confirm on inspection of the wiring for any breaks.repeat if frost appears till you correct and confirm. If you are calling a repairman keep this mind so as to get an idea of the work, to have an estimation of the work. Hope you try this out. Good day
I have defrosted fridge but regrettably the frost is starting to come back. i could not follow your instructions and could not see anything broken. the freezer looks as good as new. i wonder how expensive this is going to be. the fridge cost £1 k to buy approx. 5 years' ago. Thanks for your advice anyway I will bear it in mind. Does anyone know any good engineers in the middlesex area?
