Question about E-Machines T3092 PC Desktop
Hi! Well,I dl the chipset drivers from emachines site. I cannot connect to the internet,it tries and fails.I have already installed xp service pack 3 from USB. Could this be an issue I haven't validated xp yet either,but somehow I feel that isn't the issue. It definitely a driver issue methinks.Help please...
Posted by evil_d438 on
Gary Rice
  • 1,851 Answers
The answer has to be in the connection. Your XP doesn't have the right driver set
up for the LAN or 10/100 Set up. Try removing the driver and rebooting the system.
Also once in windows try going to start -run and type in command. Once this widow is open type in >: ping www.wnd.com and see if it 'pings' the web. if not then the issue is back to the driver - modem etc.
Do other pc's access the web on the exact same set up? If yes consider validation and then try again.
You can always re-install but I think you need to check the drivers for the
net work card driver. Good Luck
Gary @ Fix Ya
Posted on Aug 10, 2010
I have change my ops from vista to windows xp pro i cant not fine the drivers for vista ml3108b note book can you help me pls. thanks
Hello no1sugard, go to this "Website," and "Download the Updates" for Windows XP
(Service Pack 3)."
  • First make sure that you have [SP1 and SP2] already installed in your Computer?
  • To {check} which "Service Pack" you have already?
  • If not?
  • Then you must "Download SP1 and SP2 first!"
  • Open "the Computer Properties," by [Alt / Right] clicking on the Computer in the 'shortcut menu' of the "Start Menu."
If this information helped? Return and give a "Helpful Rating," please!
Thanks, paul7of9
Click here: http://windows.microsoft.com/en-us/windows/help/learn-how-to-install-windows-xp-service-pack-3-sp3
Feb 21, 2011 | E-Machines eMachines Refurbished EMA...
Http://www.driver-download.net/intel/sound-cards/82801-ba-bam-ac-97/ above sound card not running, no sound after windows xp 2007 serivce pack 3 installation
After re-installing an OS or a Service Pack,you need to do a re-install of the particular drivers(Sound,Graphic,Chipset...etc.) to keep your computer fully running.
Thank You.
Feb 10, 2011 | Computers & Internet
Just installed xp for a friend on an old ibm netvista 6794 NZU pc. Went to ibm website but can not find the motherboard or chipset drivers to allow this pc to acess the internet. Can anyone help please. ...
It's a big pain when you dont have the right driver. but try this:
1. download and install the Windows Service Pack 3 (XP SP 3) in the computer and check if it works.
and how are you trying to connect to the internet? you might just want to put in an extra PCI network card, if you want to use the broadband or if you need the usb ports to work, try a PCI USB card instead.
either ways, make sure you have installed SP3 in that computer.
cheers!
Nov 17, 2010 | Computers & Internet
Emachine t3616 changed os from vista to xp pro
On one of the cds that came with your machine are the drivers that are required for all the hardware in your system.
Should you have any problems finding them they are also available here
It would be worth downloading all the drivers for that machine and installing them one by one.
If this information was useful please click
Aug 17, 2009 | Computers & Internet
I need all drivers for emachines t2824 no internet or sound
I just checked emachines website and here is a link to the driver page for this machine and XP drivers
Feb 25, 2009 | Computers & Internet
Reinstalled xp after Vista . USB port not working
The usb drivers are part of your chipset drivers, so lets try and get this sorted. The reason that they work in Vista, is probably because Vista has added support for your chipset and XP SP2 doesn't.
Try installing XP from scratch. First you need to completely wipe your hard drive. Use the XP boot disc, you need to delete the hard drive partition as well. This way, you will start with a RAW drive.
Set up a new partition, and let the XP disc format the drive with NTFS. Do NOT use quick format. Then let XP copy the files and install.
When XP has installed, get your internet set up, and download XP Service Pack 3 from Microsoft:
http://www.microsoft.com/downloads/details.aspx?FamilyID=5b33b5a8-5e76-401f-be08-1e1555d4f3d4&DisplayLang=en
You will notice that Microsoft have written not to use if updating just one machine. Ignore this. The reason is because this is the FULL Service Pack, hence it being over 300MB.
Once you have SP3 installed, your system will restart. Open Windows Update, make sure you have this set to update all Microsoft products, then download all updates. Restart your system and check if your usb's are working.
If they are still not working, go to the laptop website and download the chipset drivers from there, but make sure you are downloading the drivers for XP. If not, then go to the Chipset manufacturer's website and download from there.
Let me know how you get on
Tim
Dec 19, 2008 | Computers & Internet
Pci device driver issu intel d945gcnl desktop board
plz try by reloading the sound driver from *********** board cd,plz post your findings
Jun 13, 2008 | Computers & Internet
Missing sound drivers
Windows XP or other operating systems, only provide generic or standard running drivers.
If you have On-Board sound, you,ll need to go to the manufacturers site, and download all the drivers relating to your motherboard. Also check that you have connected the sound-card and cables correctly. Or if your using a DVD Drive, that you have the lead to connect Drive To Motherboard. ** This is usually a 3 pin plug connector.
Mike @ Compurepair.
Feb 22, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
E-Machines T3092 PC Desktop Logo
74 people viewed this question
Top E-Machines Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Michael Thomas
Michael Thomas
efs_perpends
efs_perpends
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
