B3E071161450W02
1. Disconnect the negative battery cable.
2. Discharge the refrigerant. (See REFRIGERANT CHARGING.)
3. Remove the splash shield.
4. Remove the A/C drive belt. (See DRIVE BELT REPLACEMENT [LF].)
5. Detach the two wiring harness clamps.
6. Disconnect the magnetic clutch connector.
7. Remove the A/C compressor protector.
8. Disconnect the cooler hose (LO) and cooler hose (HI). Do not allow remaining compressor oil in the refrigerant line to spill. (See Refrigerant Line Removal Note.) (See Refrigerant Line Installation Note.)
Caution
• If moisture or foreign material enters the refrigeration cycle, cooling ability will be lowered and abnormal noise or other malfunction could occur. Always plug open fittings immediately after removing any refrigeration cycle parts.
9. Remove the compressor protector.
10. Remove in the order indicated in the table. Do not allow remaining compressor oil in the A/C compressor to spill.
Caution
11. Install in the reverse order of removal.
12. Perform the refrigerant system performance test. (See REFRIGERANT SYSTEM PERFORMANCE TEST.)
A/C Compressor Installation Note
1. When replacing the A/C compressor, remove the following amount of compressor oil from the new A/C compressor.
Amount drained (approx. quantity)
• 155 ml {155 cc, 5.24 fl oz} - [compressor oil from old A/C compressor + 15 ml {15 cc, 0.5 fl oz}]
SOURCE: 2001 Mazda MPV upper front oxygen sensor change
I replaced this sensor about 6 months ago. (If this is the sensor that is located near the firewall on the exhaust manifold under the ignition coil.) The only way to easily replace it, is to remove the MAF and air filter assy. then remove the intake plenum, remove the ignition coil, and then you'll have access to the sensor. You'll need a sensor removal socket. If the socket slips around the hex of the sensor, then you'll need to use a regular deepwell socket and cut the cable from the top of the sensor, or use a combination wrench that will fit it.
The most difficult part of removing the intake plenum is getting the nut loose from the EGR valve. DO NOT just remove the two bolts holding it to the intake plenum. It will not line up correctly during re-assembly and may not seal tightly either.
This took about a Saturday to do. You'll need new plenum gaskets to replace the old. While your at it remove the throttle body and clean the carbon from the ports that lead to the EGR valve and replace that gasket as well. The gaskets will run about $30.
After removing glove box, you will see door on a black box that secured by 2 screws (top and bottom) After opening that door it will come out with resistor that looks like a card. Replace it, and it should fix it.
