Question about HP ProLiant ML370 G4 Server
My HP Proliant ML370 G4 can not boot. 1 of the logical drive has a problem and in interim recovery mode. how come it can not boot? there is also an error saying the battery is unable to charge. cache battery. Please help!
Posted by erwin_mendoz on
Anonymous
    New Friend:
    Problem Solver:
  • 5 Answers
Dear erwin,
as per your writing the server raid has broken .. its may be a problem with a hard disk , first you have to check the hard disk state . to do that you should enter into raid bios . don't try to something on that , just see the status of logical drive then which are the disks includes on that raid
in you post also it may give the details of failed disk ids
then you may have problem with your batt. unit , for that please do the above steps first then back with that...
Posted on Aug 11, 2010
Install new OS
Use the HP Smartstart CD and configure the with array with 2 arrays and 2 logical drives. The first with OS array on RAID 1 (2 drives mirrored). The second array on RAID 5 (3 drives minimum).
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareDescription.jsp?lang=en&cc=us&prodTypeId=18964&prodSeriesId=345557&prodNameId=344318&swEnvOID=1005&swLang=8&mode=2&taskId=135&swItem=MTX-bd347636805e4917a617382469
Make sure to use Insight Manager for worry free monitoring.
Oct 22, 2012 | HP ProLiant ML370 G4 Server
We have hp server ml370 when i restart the server its stopped on attempting boot from hard drive c and never continue
This is because either the image on the hard drive is bad (corrupted, missing boot sector, etc) or because the hard drive itself has some issue like corruption etc.
If this is a mirrored raid array (two drive mirroring each other) I would try to remove one of the drives and boot again. If that does not work reinsert and remove the other drive and try to boot.
regards,
Mike
Oct 21, 2012 | HP ProLiant ML370 G4 Server
Compaq ProLiant ML370 G4 (374490421) Server - Windows xp issues
Servers need the Drivers for the Drive array card.
The server should have come with a smartStart CD that has the drivers for it.
You are NOT going to get another OS on this machine unless you load the drivers for the adapter.
... and why put XP on a Server? that's not the optimal OS for the hardware.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/lisa_52daba487e5b4d53
Dec 12, 2011 | Compaq ProLiant ML370 G4 (374490421)...
Cannot boot from CD rom? thank you in advance
CHECK IF THE CD IS BOOTABLE.
GO TO BIOS SET THE FIRST BOOT DEVICE TO CD ROM AND DISABLE ALL OUTER DRIVES. SAVE AND REBOOT. IF THE CD IS BOOTABLE THEN IT WILL SURELY BOOT FROM IT.
REGARDS.
PLZ. DON'T FORGET TO RATE
Jul 05, 2011 | HP Compaq ProLiant ML370 G4 Server
We recently had a HD failure on our HP Proliant ML370 G3 server. The failed drive is in a RAID 5 configuration, so we simply purchased a replacement drive, and installed it. The problem, is that it...
why not ask HP this, and not in chat rooms. (here)
raid recovery is fully documented at Hp.com
for sure, and even forum help...
you'll have to switch to the commercial, side,
https://h30434.www3.hp.com/
type this in there box.
May 13, 2017 | HP ProLiant ML370 G3 Server
HOW CAN I CANNECT HP ProLiant ML370 HARD DRIVER
The best way to connect is to use the Ethernet cable to connect each pc to each other or use a Ethernet hub to connect the two together.
Good Luck
C2S
May 27, 2010 | HP ProLiant ML370 G4 Server
The system is setup using the RAID 5 config, now out of 5 drives it says 'OK' for 3 drives on 0, 1 & 2 and for 3 & 4 it says 'Replacement'. Is there any way of finding the correct Logical sequence...
Dont you have any levelling inside the machine? Go open and check.
When you have replaced the 2 defective drives with a new one, restart the computer and Raid 5 will automatically rebuild.
Jun 18, 2009 | HP ProLiant ML370 G4 Server
Harddrive array sequence causing system in booting
If the only drive you changed was the drive that failed and all the others are in the correct sequence, then that's a good thing.
The next question is, did you have this system setup in a RAID Array and if so, what RAID configuration were you using (RAID 0,1,5, etc.)? Some RAID configurations allow you to replace a failed drive and not lose data, but I will need to know more about how you set the system up in order to help you more.
Hp proliant ml370 g4 rebooting problem
Try to boot from smart start and do offlinr diagnostics.have you purchased second cpu seperately? Check the CPU compatibilities.
Jul 16, 2008 | HP ProLiant ML370 G4 Server
HP ProLiant ML370 G4 Server Logo
602 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
