Loosen the screws on the top usually under a plastic cap that comes off to expose the hinge there will be 3 then move the door around and retighten them. If it needs to be adjusted up the easiest way is to remove the top hinge and then pick straight up on the door it will come off the bottom hinge look for plastic washers on top and bottom remember where they go you can add a couple metal washers on the bottom hinge then put the plastic one back on this will raise the door slightly. You can order plastic washers or even get brass ones from a hardware store they work fine. good luck
