Whirlpool GB2SHKXL Bottom Freezer Refrigerator Logo
Posted on Aug 09, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
The freezer is cold but the refrigerator is not cold at all
Anonymous
Level 3:
  • Master 1,891 Answers
  • Posted on Aug 10, 2010
Anonymous
Master
Level 3:
Answers
1891
Questions
0
Helped
409353
Points
5205
Ck the evap fan it may not be going or is running slow / also ck for ice build in freezer ( back ) this will solw or stop air flow .. mm
My Amana 19cu ft refrigerator, freezer on the bottom. Refrigerator stopped working, freezer is still working, MODEL DRB1901CW. S/N109533070CE
There are plenty of reasons this could happen like the following: PROBLEM POSSIBLE CAUSE Loud operating sound level • See "Sound Information" section for explanation of normal operating sounds Freezer too warm. Compressor not operating • Freezer temperature set too warm • Defective compressor • Defective overload or relay Refrigerator too cold • Refrigerator temperature set too cold • Chefs Pantry control set too cold or misaligned allowing freezer air to escape into refrigerator section • Freezer temperature set too cold • Restricted condenser air • Refrigerant shortage or restriction • Refrigerant overcharge Freezer too warm. Compressor cuts off on overload • Heavy usage • High ambient • Restricted condenser air • Defective condenser fan motor • Loose or missing condenser fan blade • Improper voltage • Defective relay or overload • Compressor motor winding • Non-condensibles in system • Refrigerant overcharge Freezer too warm. Compressor operating • Freezer temperature set too warm • Restricted condenser air • Defective condenser fan motor • Opened door • Heavy usage • Defective freezer fan motor • Opened defrost thermostat • Opened defrost heater • Loose or missing freezer or condenser fan blade • Heavily frosted evaporator • Refrigerant shortage or restriction • Inefficient compressor Refrigerator too warm • Refrigerator temperature set too warm • Freezer temperature set too warm • Return air or air supply duct blocked • Chefs Pantry control set too warm or air supply tube blocked • Heavy usage • High ambient Problem Possible Cause Freezer too cold • Freezer temperature set too cold Long off cyde • Low ambient • Freezer temperature set too warm Short off cycle • Heavy usage • High ambient • Freezer temperature set too cold • Light constantly on • Poor door gasket seal Long or continuous run cyde • Heavy usage • High ambient • Inadequate condenser air flow • Freezer temperature set too cold • Loss or restricted refrigerant Short run cycle • Light usage • Low ambient • Freezer temperature set too warm Exterior cabinet condensation • High humidity. Design accepts beads of water on cabinet exterior after 4 hours with 0° to 2°F (-18° to -17°C) freezer food temperature and 38° to 40°F (3° to 4°C) refrigerator food temperature in 84% R.H. conditions. See "Typical Sweat Pattern" section under above conditions. • Freezer temperature set too cold • Poor door gasket seal • Insulation void
My fridge no longer cools, but the freeze seems to be working.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Cold ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/cold
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, cold related issues. ... by side cold but not cold enough frezer cold but not enough to freeze Fans blow when ... Kenmore cold spot model 106.73282301 not cold in fridge and freezer isn't as ... the unit initially cools, then when camping in cold weather, it does not restart to ...
Avanti FF1008W (97 cu ft) Top Freezer Repair Questions ...
www.fixya.com/.../p1394527-avanti_ff1008w_top_freezer_refrigerator
Recent Avanti FF1008W (97 cu ft) Top Freezer Refrigerator questions, ... Free expert DIY tips, support, troubleshooting help & repair advice for all Refrigerators. ... The cooler isn't working On avanti model WC681BG-2 ... Avanti 308ywt compressor keeps running but frig will not get cold ... Does not cool anymore, still runs.
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator Power ...
www.fixya.com/search/...avanti_ff1008w_top_freezer_refrigerator/powe...
Avanti FF1008W (97 cu ft) Top Freezer Refrigerator, power related issues. ... Power back on and the door ice dispenser unit says: Power Freeze - 88 Power Cool - flashes ... Refrig lights came back on but not tempature lights well u have a problem of ... refridge stopped working after a power surge fridge was plugged into a ...
2answers
LG french door refrigerator with bottom freezer. Freezer is cold but the refrigerator is warm
Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...---/Refrigerator-freezer-is-cold-b...
Refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
LG Refrigerator Freezer is Cold But Refrigerator is Warm ...
www.repairclinic.com/...Refrigerator/...-/LG-Refrigerator-freezer-is-cold-...
LG refrigerator freezer is cold but refrigerator is warm? Use our DIY troubleshooting & videos. Then, get the parts you need fast. Return any part for 365 days.
4 Reasons Why Your Freezer is Cold but Fridge is Warm ...
www.bestfridgereview.com/freezer-is-cold-but-fridge-is-warm
Jul 25, 2014 - Your freezer is cold but refrigerator is warm? This can be a very big problem. Check Out the top 4 most common problems and their solutions ...
Why is my refrigerator not cooling? - Refrigerator - iFixit
1helpful
How do I keep my refrig/freezer from defrosting in the winter when store in the garage.
There is only one source of cold in many refrigerators. If yours is a top freezer, then most likely it is in the freezer.
But the thermostat that you set temperature with is in the refrigerator, not the freezer.
In the cold garages, what can happen is that the refrigerator stays cold enough that it does not call for cold. So the freezer does not get enough cold.
The freezer control works by diverting cold air into the freezer WHEN THE RERIGERATOR HAS TURNED ON THE COOLING. If it is not turned on, oh well.
The best you can do for this is to put both on max cold. Then the refrigerator will call for more cold at a lower temperature, and the freezer will get it more often and will divert more when it is cooling.
This can result in the refrigerator freezing things too. You can try raising the refrigerator setting JUST A LITTLE and see if both work, but keep freezer on max cool.
This works for my situation, but ambient temperature fluctuations in the garage make this dicey. We don't put things like lettuce in the refrigerator in the garage in the winter because freezing damages them.
Good Luck
My Roper refrigerator stopped getting cold, although the refrigerator lights and the fan in the freezer works. What is the problem?
If the freezers warm, possible defrost timer bad, if freezers cold, set to middle setttings on both dials, the 1-10 OFF dial operates the compressor, the COLDER/WARMER dial operates the flapper door that regulates freezer air into the reefer box, if set to max cold that makes cold freezer, not reefer.
Our 3 months old refrigrator will get so cols that freezes food products.
There are actually 2 cold controls on refrigerator-freezers. The main control is within the refrigerator cavity, the other is located in the freezer cavity. The one in the freezer is usually only a cold air deflector. It takes the cold air that is produced and divides it proportionally between the freezer and refrigerator sides. Set the control in the refrigerator to about mid-range. Set the control in the freezer to mid range. That is your starting point. If the freezer is not cold enough, adjust the freezer control. If the refrigerator s not cold enough, adjust the fridge control. After any adjustments, you MUST wait at least 24 hours for the temp to equalize before making any more adjustments. It may take a week to get it set right. This is true for all refrigerator-freezer combinations. Be patient.
1helpful
THE REFRIGERATOR IS BUT FREEZER IS
the damper vent door that lets cold air from the freezer into the refrigerator isn't opening to let cold air flow,check to see if its iced up,or the cold control that operates it is working
1helpful
The refridgerator has not been cold enough, the freezer is fine what should i do?
The refrigerator itself get cold air from the freezer. There is a small opening that lets air from the freezer to go to the refrigerator area. make sure the cold air from the freezer is getting there. Sometimes there might be a restriction on this vent therefore the refrigerator is not getting enough cold air from the freezer.
2helpful
MY FREEZER IS GETTING TOO COLD AND THE FRIDGE IS NOT GETTING COLD AT ALL
In most refrigerator freezers, the refrigerator gets its cold from the freezer. The evaporator fan circulates air over the coils in the freezer and cold air circulates into the refrigerator through vents. If the vents are blocked or closed, then the fridge will not get cold enough but the freezer will. If neither is cold enough, then the number of possibilities increases.
Lowering the freezer temperature will increase the cooling cycle activity. Setting the refrigerator temperature may have little affect on the cooling cycles because it simply changes the vent opening size. Decreasing the fridge temperature opens the vents more and increases air circulation from the freezer.
The temperature can be adjusted using the controls found inside the refrigerator or freezer. The ideal freezer temperature is about 0 to 5 degrees (F) and about 38 degrees (F) for the fridge.
Measure the temperature by placing a cup of water with a cooking thermometer into the refrigerator for about 2 hours or more. To test the freezer, substitute alcohol or cooking oil.
Top Whirlpool Refrigerators Experts
Mike Cairns
Mike Cairns
ZJ Limited
ZJ Limited
Are you a Whirlpool Refrigerator Expert? Answer questions, earn points and help others
