If the unit is at a strong angle to the screen, you may need to reduce it. With the projector mounted high, the bottom of the screen is further away. The projector focuses the entire image the same and cannot compensate for the difference in distance.
On the remote control of the projector, you'll notice an "Auto Image" button (or similar to it). What it does is synch the signal between the PC and projector. You might also want to check the keypad of the projector, normally there's an Auto button on there also.
Check the Video cable that feeds the projector, could be a broken cable or a pin bent -worst case the connector on the projector has broken. Try the VGA cable on your computer screen. The lamp does not need replaceing, the lamp emmits white light only.
this could be the main board or the dmd board on the light engine. you can try disconnecting, cleaning the connections with an approved board cleaner, blow the connections completely dry and then reseat the connections firmly. This has worked many times for me. If the problem still persists you will have to have the projector tested to find out what needs to be replaced.
reset the settings to factory default and swap out the cables. if it's ok on computer 1 and not on computer 2, you have a bad port. may need to resolder or replace the entire board.
1.
Connect the external display port on your laptop computer to the projection system, and then turn on the projector. For information about connecting external devices to your laptop, see the documentation for your laptop computer.
1.
Set the display resolution of your laptop computer to match the resolution of the projector system. First, on your laptop, open the Display Properties dialog box by using the Display icon in Control Panel, and click the Settings tab. Then, in Screen resolution area, move the slider to adjust the display resolution of your laptop. If you don't know which setting to choose, try 800 x 600 pixels; this is a common setting for many projector systems. YOURS sounds like 640x840.
3.
If you have audio in your presentation, connect a cable from your laptop's audio output jack to the audio input jack on the projector, and then test the volume by playing a file that contains sound.
4.
Start the Player on your laptop. If you want to only display the Player on the big screen, and not the desktop background, maximize the Player or set it to play your video using the entire screen (full-screen mode).
