Question about Jobo Giga Audio Players & Recorders
Jobo giga v u pro
I was using the machine looking at photos. The screen froze. It would not turn off. Light was still green.
I left it for a while, and the screen blank.Plugged it into the mains the light by the setting button has gone red and the on off button will not work. I cannot get it to do a thing. This is only the third time that I have used it and bought it new in January
Posted by Photomad123 on
5 Related Answers
Anonymous
  • 10 Answers
SOURCE: Cannot Turn on Monitor and Standby Red light is gone
If the power cable and power outlets are working and the TV still won't power up, then there's nothing much you can do. The power supply unit in your TV is blown. You'll have to get it replaced.
Posted on Jul 29, 2007
Anonymous
  • 377 Answers
SOURCE: Jobo Giga One free space problem
Why don't you try to format your external drive. There's a variety of options where you can format it. The first one is Go to the My Computer then Right Click on the Icon of your External Drive then Select Format, it is better to select full erase of the the drive.
Posted on Mar 02, 2008
Anonymous
  • 377 Answers
SOURCE: Wont switch on.
removed the battery & put it back after 42hrs.. just to reset and delete the settings you made there..
Post back again, & feel free to contact me..
~pinc
Posted on May 18, 2008
Anonymous
  • 5 Answers
SOURCE: TV Won't come on...
Hello to all from Tom Arnold, WA6OVP
Subject: Repair of computer monitors or flat panel TV’s.
History:
Recently my wife's 27-inch AKAI (LCT21AS) 27-inch flat panel HDTV with DVD player quit working. Years ago, when I had an analog computer monitor quit operating; Joe Fadden WA6DDF had mentioned to me, that often computer monitor problems were caused by the monitor's power supply. Joe also said these power supply problems were often caused by failed electrolytic capacitors. Joe said he was able to fix many computer monitors by just changing all of the power supply electrolytic capacitors. Rather the fix that failed monitor, I just a bought a new one.
Symptoms:
The inoperative HDTV had been bought at COSTCO and had already been returned once to a COSTCO repair center for repairs. Cost to ship and insure the HDTV was 67 dollars. We received back a new HDTV set. Turn around time was over a month, with many long distance telephone calls being required. The new HDTV worked for about three months after it was received. When the returned HDTV failed, it trapped a DVD disc that had been left in the HDTV DVD player. The new HDTV failure symptoms were the same as the original HDTV failure. The red led indication would not change to green when the remotes power on button was pushed. There was no picture and no sound. The remote is required to operate the TV set.
Economics:
My wife's HDTV with internal DVD player was very expensive. Worse yet, the trapped DVD disc was the movie Flash Gorden Space Soldiers 1936. A local TV shop wanted 85 dollars to look at the failed HDTV; repairs were 75 dollars labor an hour plus parts. I quickly figured out that if I could fix the problem it would save a lot of time and money.
Internet Search:
I checked the Internet to determine if other AKAI owners had similar problems with their HDTV sets. There were lots of AKAI 27 inch and 32 inch HDTV set owners listing problems. Without exception all of the complaints concerned the HDTV power supply PC board and failed electrolytic capacitors.
General Internet Consensus:
Most of the AKAI HDTV sets worked just great and that many had been sold worldwide. There were some AKAI HDTV sets that did have power supply problems. Most of the AKAI HDTV set owners were not very pleased with either AKAI or the COSTCO response to the inoperative HDTV power supply problem.
Trouble Shooting:
All electrical power was removed from the HDTV set. The HDTV was placed face down on a workbench with a piece of cardboard to protect the display screen. The HDTV back panel cover was removed. There were many screws of several different sizes. The power supply PC board was separate from the rest of the set's components and was easily identified. The power supply PC board contained several different individual different voltage power supplies. Three electrolytic capacitors located on the PC board had obviously failed. The tops of these three capacitors were puffed out. Often when electrolytic capacitors fail they get over heated and the top of the capacitor is puffed out displaying an over pressurized appearance. The power supplies on the PC board were of the switching type. Switching type power supplies are also used in computer monitors to save money and weight.
Power Supply PC Board Removal:
The power supply PC board was mounted to the HDTV back panel with several screws. These screws were removed. There also several multi-pin connectors attached to the PC board. These connectors were numbered with a black felt marker to ensure correct reinstallation. The connectors were Hot-glued in place. A sharp knife was used to remove the hot glue. The connectors were removed.
Repair:
The three suspect failed capacitors were easily removed. The three capacitors were each 1000 ufd and rated at 16 working volts. The other power supply PC board electrolytic capacitors were visibly checked. Three new capacitors were installed, they were rated at 1000 ufd at 25 working volts. On the PC board the three electrolytic capacitors were in just one of the power supply circuits and were identified as EC18, EC19, and EC20.
The New Electrolytic capacitors:
These were low impedance / high reliability radial lead polarized aluminum capacitors, they have a plus and minus connection pins. Correct installation of any polarized capacitor is required. The three new electrolytic capacitors were specifically designed and rated for service in switching type power supply circuits. Switching type power supply electrolytic capacitors need to be both very robust and designed for use in high frequency circuits. General-purpose aluminum electrolytic capacitors should not be used in switching type power supplies, if capacitors designed for switching power supplies can be obtained.
Final Repair Steps:
The PC board was reinstalled without the electrical connectors to the PC board being hot glued. The HDTV back panel cover was refastened. Watched episodes one through five of Space Soldiers. It was well worth the time and three electrolytic capacitors to fix the problem. The repairs saved a lot of time and money. The repair was very simple and not the least challenging. It took longer to remove and then reinstall the HDTV back cover panel than it took to replace the three failed capacitors.
Safety:
These types of repairs should not be attempted without a complete understanding of the dangers involved with working on electrical equipment, especially working around power supplies and charged capacitors. Proper desoldiering and soldiering techniques need to be used.
Conclusions:
Flat screen computer monitors and TV sets do fail. Repairs of electronic equipment can be very expensive. When your computer monitor or flat screen TV does fail, you might consider a visible inspection of the equipments power supply. A simple repair might save you a lot of time and money.
Posted on Aug 21, 2008
olayoju victor
  • 191 Answers
SOURCE: LG 32LC2D Power light Blinks but set will not power on.
change your adc(analog to digital converter) board will help out
Posted on Oct 11, 2008
The screen does not illuminate correctly. The device is on but it is virtually impossible to read the screen
Did you take the screen apart to clean it? did it happen on its own? How old is the device are you still in warranty?
Oct 16, 2009 | Jobo GIGA Vu PRO evolution MP3 Player
Giga ONe hard drive reformat
You can format your giga one hard drive in MS-Dos mode.
1. Go to Start--> Run
2. type CMD to enter the DOS
3. select the giga one drive path (i.e. if it shows as E drive then simply write E: in DOS and hit enter.
4. type format
thats all that you have to do to format the giga one drive.
Jul 28, 2009 | Jobo GX1040 GIGA ONE Silver 40GB Portable...
Lost 40Gb of photos-7Gb not lost.
First of, I suggest you use USB Flash Drives of High Value., like 500 to 1G. Or a second Hard Drive 2G.
If you lost 40G of data, it is gone. Just remember to use the EJECT format to remove all external devices. If you do not, you can loose data.
Feb 15, 2018 | Jobo GIGA Vu PRO evolution MP3 Player
Fromating Giga one
you need to go to the jobo site, find the driver/software/service link, in that you will find the giga one formatting tool, download and use that. i had the same problem when i purchased my original giga one, i used windows to format the drive - but as people find out windows is unable to format the drive correctly ie fat 32, and you then get an error message. in the formatting tool it tells you why what the different error codes are and error 1 means drive not formatted to fat 32, im not sure how old your giga one is but when i purchased mine approx 4yrs ago it never came with a proper manual and there was no support on the jobo site at the time. I think a lot of these minor problems could be avoided if it came with a manual and explained whats needed to clear the internal hard drive
Mar 19, 2009 | Jobo Giga One 40GB Portable Storage MP3...
I have 2 problems with 2 photo storage devices
my company the IT Partnership might be able to help , but i need more details of how the devices failed and what is their current state
Jan 25, 2009 | Jobo GX1040 GIGA ONE Silver 40GB Portable...
Gigavu PRO
If the Giga Vu hangs, hold down the two end buttons of the 5 along the bottom, then press the power button for a few seconds. This should now turn off the device. Give it a few seconds then turn it back on. Some times I have to plug in the power for a couple of minutes before turning it back on.
Jun 27, 2008 | Jobo GIGA Vu PRO evolution MP3 Player
Wont switch on.
~pinc
Apr 28, 2008 | Jobo GIGA Vu PRO evolution MP3 Player
43 people viewed this question
Top Jobo Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Jobo Audio Player and Recorder Expert? Answer questions, earn points and help others
