If you can find a higher rated GFCI receptacle it may help. But the first thing is to use 12 ga wire (NOT 14), and to get a good and tight connection to the load lug. Use the screw terminal, not the push-in holes. If you can remove the screw, do so. Then shape the end of the wire into a nice hook and then use a hammer and anvil to flatten it slightly. Then insert the screw nice and tight. If you can manage a 10ga wire, use that.
