Question about Apple iPad 32 GB WiFi Tablet PC
I want to synchronize my email on my PC's Outlook to the email on iPad. MobileMe does Contacts and Calendar but not the email. Is there a program or technique which will do it all?
Posted by lewis_and83 on
Anonymous
  • 1,234 Answers
Hi Sir
You Can Use The Itunes App To sync Your Ipad
Now , How to Sync iPad with iTunes 9.1?
There Are 4 Steps .
1. Connect your iPad with the USB cable.
2. Open iTunes and wait for it to recognize your iPad.
3. Depending on your configuration, auto-sync should begin.
4. If not, then manually select whatever features you like to sync your iPad with and press the Sync button.
That’s it! Like I said, it’s the same method like you sync your iPhone or iPod Touch.
Posted on Aug 10, 2010
Can I sync Outlook EMAIL with my IPAD3?
This should be fairly easy on the iPad 3 go to settings > mail> select your provider>enter your credentials
Mar 18, 2012 | Apple iPad 32 GB 3G Tablet PC
Tip
Keeping Data Safe in iPad
With the evolution of iPad computing become more accessable at anywhere. In the IT industry iPad becoming the safest computing device to use. The hardware and software security combination of the iPad makes it more secure and safest computing device than Macintosh or PC. Recently no remote attacks are faced by the iPads, but the major security risk is physically losing the device.The passcode and encryption methods in iPad makes the data safe and secure.
With the use of data protection we can encrypt the e-mail messages and attachments. To enable the data protection go to Settings--> General-->Passcode Lock and then enter a four digit code twice.To make the passcode more safe tun off the Simple Passcode option on the same page then you can use longer codes. The passcodes can become more secure and strong by installing iPhone configuration utility.
Remote wiping is also another utility to delete data on a lost iPad when it connects to the internet.If you have MobileMe account, you can set this by
enabling My iPad in Settings--> Mail,Contacts,Calendars--> MobileMe.Corporate or Business users who are using Microsoft Exchange Server or Kerio Connect can use Exchange ActiveSync support to wipe their devices. All these things are managed on the server not on the iPad.So we will need to work with our IT administrator.
There is also availablity of secure email connection in iPad. Perfectly configured Microsoft Excange servers encrypt data by default. If you are using the IMAP or pop3 server and it supports SSL you can go to settings-->Mail,contacts, calendars-->youraccountname-->Advnace on iPad and enable it.
If you loose your iPad the first things you should do is change your password and deauthorize the device for any services such as Dropbox or iDisk that you used for connecting to it.
on May 22, 2011 | Apple iPad 32 GB WiFi Tablet PC
I cannot access old Outlook (2007) emails on my Ipad. I can get recent emails but how do I search and access old emails like I can in Outlook?
1)Press settings icon (the one with the cogs) 2) than scroll to Mail, Contacts, Calendar and press it. 3) Find your email account you want to modify and click it 4) find the section on the bottom that says "Mail Days to Sync and press the button 5) Now, you have limited options there, but you can pull email from 1,3 days or 1,2 weeks, 1 month or No Limit. If you click no limit it will pull your entire inbox. So, I might be careful in saying it will drain battery power. And or take room on your ipad away. So, if you have old emails with big attachments, be weary. Plus, depending if you are pulling all this mail over 3G you should take note of your data limits.
Hope that helps.
Jan 29, 2011 | Apple iPad 64 GB 3G Tablet PC
I have just got an iPad 32GB. I wish to move all my emails from my PC to the iPad i.e. my Outlook mail folders, all the emails in those folders etc. Can this be done ?
You will need to setup a Exchange mail account on your ipad to receive all the mail and calendar items that you see on your Outlook mail and calendar.
Here is how to add an exchange account:
. From the Home Screen, tap Settings
2. Scroll down and tap Mail, Contacts, Calendars
3. Select Add Account > Microsoft Exchange.
4. Now type into the following information:
* Email: your email address
* Username: your-Exchange-User-name
* Password: your-mail-password
* Description: It's Optional
* Server: ****.com
For your username, and server names, you will need to contact your company's IT department for the credentials. But your username is the one your IT dept. gives you for email access and password. exchange server name is the server address to access your mail.
Dec 28, 2010 | Apple iPad 32 GB WiFi Tablet PC
How do I sync my ipad to my outlook calendar at work
you have to create an exchange account within mail/contacts/calendars tab in settings
Dec 07, 2010 | Apple iPad 32 GB WiFi Tablet PC
How to use out look on i pad
The answer is yes, You can sync apple ipad with outlook, there are different ways to do this, I will show you way where you can sync between your Google calendar outlook and your ipad.
Please follow the next steps.
  • If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
  • Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
  • Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
  • Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
  • Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
  • Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
  • A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
That's about it now your ipad is synced with outlook through your google calendar.
Hope this will help you with your problem syncing ipad with outlook
Jul 29, 2010 | Apple iPad 32 GB WiFi Tablet PC
Aloha! i just got a new ipad and would like to
* If you don't have a Google calendar then you can create one here http://www.google.com/calendar/
* Now you'll have to download the Google Calendar Sync, http://www.google.com/support/calendar/bin/answer.py?hl=en&answer=89955
* Follow Google instructions on How to sync Google calendar with outlook, you'll have to insert your email and some other steps that are details at the link above.
* Now it's the ipad turn, from SETTINGS on your iPad select mail then contacts and calendars now select the add account then select Microsoft exchange
* Still with the ipad, from within the Microsoft exchange enter your gmail/email address, leave the domain field empty.
* Enter your password into the screen. Select next from the upper right corner. A message saying “Unable to Verify Certificate” will come up, Click accept.
* A new window, populate the server field with “m.google.com" click next. A new window will ask you to select what will be synchronized from the Exchange server, make your selections and select done.
Jun 19, 2010 | Apple iPad 32 GB WiFi Tablet PC
Syncing Outlook 2007 email with iPad
Jun 05, 2010 | Apple iPad 32 GB WiFi Tablet PC
Apple iPad 32 GB WiFi Tablet PC Logo
902 people viewed this question
Top Apple Tablets & eReaders Experts
 Larry
Larry
john smith
gaucherre
Are you an Apple Tablet and eReader Expert? Answer questions, earn points and help others
