Question about Dishwashers
Getting error code 0E on LD-14AW3 model dishwasher after 2 minutes. Checked drain hose and water seems to be coming out but won'y go any further in cycle Also makes a loud humming noise when running.
Posted by les_callear on
Terence Fourie
  • 909 Answers
To little info, but looks like pipe is much to low. Not getting the opportunity to fill up properly.Raise it higher.(Im asuming that you can hear the drain pump run and water is being pumped out as wall.
Posted on Aug 09, 2010
My LG dishwashing machine model LD 2131 SH displays a F error. What does it indicate?
LG DISHWASHER ERROR CODES AND DESCRIPTION MODELS LD 1420W2 D1420WF LD...
ERROR CODES; FAULTS & REMEDY ERROR DISPLAY [IE]
Inlet error.
Condition: Not reached to the normal water level in spite of 10 min. water supply.
Possible causes:
  1. The Water Tap is not opened.
  2. The Inlet Hose is twisted.
  3. The Filter of inlet valve clogged by impure water.
  4. The Inlet Water Valve is normal ?
  5. The water pressure is very low. ( below 0.5 kgf/ )
  6. Inlet valve is blocked by safety device for leakage sensing.(In case of Inlet Valve).
Remedy
    • Open the Water Tap.
    • Repair the Inlet Hose.
1.Close the Water Tap.
2.Unscrew the Inlet Hose (Inlet Valve side)
3.Clean the Filter of Inlet Valve.
> Replace or repair the Inlet Valve.
> Check the water remain on the base.
1.Check the point of damages and repair or replace the related parts.
2.Disconnect the inlet hose to dishwasher to unlock the safety valve.
ERROR DISPLAY [OE]
Drain error.
Condition: Not fully drained out in spite of 5 min. drain operation.
Possible causes:
  1. The Filter clogged.
  2. The Drain Hose twistec or blocked.
  3. The Drain Pump/Motor or circuit is troubled.
Remedy
    • Clean the Filter.
    • Remove the cause of twist or block.
    • Replace the Drain Pump/Motor or repair the Circuit.
ERROR DISPLAY [E I ]
Leakage error.
Condition: The water level in Tub goes down during operation.
Possible causes:
  1. Water leakage in Hose connections.
  2. Water is leaked by damages.
  3. Impeller of the washing Pump is worn away.
  4. The Thermal Protector of the washing motor is functioned
Remedy
    • Replace the connections of Hose.
    • Check the point of damages and repair or replace the related parts.
    • Replace the washing pump.
    • Check the applied voltage.
ERROR DISPLAY [ F E ]
Excess error.
Condition: Excessive water is supplied than normal water level.(Automatically drain Pump operated.).
Possible causes:
  1. The Inlet Valve is troubled.
  2. The Air Break is troubled.
  3. The Sensor Assembly is troubled.
  4. The Controller is troubled.
Remedy
    • Replace the Inlet Valve.
    • Replace the air breaker.
    • Replace the sensor assembly.
    • Repair or replace the controller.
Jul 09, 2017 | Washing Machines
Ld14aw3 error code 0e lg dishwasher
LD 14AW3 Service Manual pdf
Mike - Here is the service manual.
Use - ld14aw3
Apr 07, 2014 | Dishwashers
Error code 0E
OE is OUTLET ERROR.
More often than not, a blockage is in the pump(not that easy to get to and quite a long step by step process)
You might also find the blockage at the end of the drain hose, where it connects to the drain pipe- remove the hose clamp and inspect hose and spigot.
May 04, 2010 | LG 24 in. LD-12BW5 Free-standing...
E1 display in diswasher
If you've checked everything, you will need to replace the impeller possibly.
Leakage error > Conditon: Excessive RPM of washing motor happened during wash cycle due to water leakage. Possible cause: Water leakage in hose connections,water is leaked by damages. The motor water seal leakage of sump assembly. The height of drain hose connection ( sink drain hose ) is not over 20". Impeller of the washing pump is worn away.
Mar 30, 2010 | LG 24 in. LD-12BS6 Stainless Steel...
Bottom spray arm on our LG dishwasher LD-14AW3 won't spin.
sounds like no water going into the machine. you may need a water inlet valve.
Nov 07, 2009 | LG Dishwashers
Instead of showinf a time my LG dishwasher (LD-2120w) has code: F on then during a cycle it stops and flashes 0E. I have found OE means to clean the filter which i think i have done, but the priblem is...
With an OE error, the next step is to follow the drain hose from where it connects to the dishwasher through the point where it connects to the drain.
Look for crushed hose, kinked hose. Then look for a plugged drain connection.
Please report back what you find. There are other things that ~could~ cause the problem. OK?
Aug 09, 2009 | LG 24 in. LD-12BW5 Free-standing...
Error code OE; dishwasher stops with error message 2 min into cycle, drainage seems OK, water doesn't appear to pump into machine - any advice?
The most common cause of an OE error code on a modern LG dishwasher is:
1. Blocked drain hose
2. Obstruction in the sump area (beneath the filter, which needs to be removed to check for onstruction)
3. Failing drain motor.
else you need to REPLACE THE PCB POWER CONTROL BOARD
Good Luck!!!
Apr 19, 2009 | LG 24 in. LD-12BW5 Free-standing...
I have a LG Diswasher LD 2050 with a trouble Code E1. The manual says "Water leakage in hose connection" "water is leak by damage" Ihave check and everything is Okay. It let water in and when it start...
The most common problem on an LG dishwasher when error code E1 is reported but there is no actual leak found is the problem of a natural syphon being created by improper installation of the dishwasher. Pretty easy to fix:  Either add an Air Gap valve (available at any hardware store for almost free) or follow the drain hose from the dishwasher to the drain. Raise the hose and attach the hose to the up onto the bottom of the countertop. Adding that "rise" eliminates the possibility for the syphon effect to drain the dishwasher before the drain cycle begins.
If the hose ever fall back down, the problem will return immediately.  Adding the Air Gap valve is harder but is far more permanent (and complies with construction codes that really should not be ignored.)
Apr 17, 2009 | LG 24 in. LD-12BW5 Free-standing...
Dishwasher states there is a water leak when visually there isn't
Assuming that you have checked under the dishwasher for a leak (through a faulty sump gasket):
Since there is not actual leak, check the following:
-Confirm that the height of Drain Hose connection (sink-Drain Hose) rises greater than 20′ _minimum_ as it travels to the drain connection.
-If that does not solve the problen, it is probably a worn/broken Impeller of the Washing Pump.
Unless you are mechanicly incliend, a service call is probably the way to do. If you need further steps, please reply. Otherwise, after you ahve used the advise, please accept this solution.
Mar 28, 2009 | Dishwashers
Water won't drain
Hi fixitfran,
I'm Harvey the Master Plumber.
Your problem is: You have pulled the dishwasher out and checked hose. No kink in line. You have taken cleaned out dishwasher and no clog. You poored water into dishwasher and it drains from the bottom not throught drain hose. You have checked the drain hose on the bottom of the dishwasher and to no avail....you don't know what is causing this issue....can I help you out with this? LG-14AW3 Dishwasher does not drain properly and then powers itself off mid cycle. Filters are clean and there are no kinks in the drain hose. How do you fix this and will it be very expensive.
Have you recently replaced the garbage disposal? Sometimes the installer forgets to remove the knockout plug. All of the disposal manufacturers plug the d/w connection in case it is installed where there is no d/w. If there is a d/w, the plug must be removed.
Feel free contact me again!
Please give me a rating here at fixya.com before you sign off
Thank you,
Harvey your Master Plumber
Sep 27, 2008 | Dishwashers
Dishwashers Logo
154 people viewed this question
Top Dishwashers Experts
Michael Thomas
Michael Thomas
Marvin
Marvin
