Question about Master Replicas Star Wars Yoda Lightsaber .45 Scaled Replica
I can't get the battery case out! Help! - Master Replicas Star Wars Yoda Lightsaber .45 Scaled Replica
Posted by haasedvm on
Anonymous
  • 175 Answers
Please consult the experts...........
Posted on Aug 09, 2010
Where can I get battery for groovy girl va va Vroom scooter
You need to check what batteries your scooter uses by removing
the cover and reading the information on the side of the battery,
Jan 17, 2015 | Health & Beauty
Tip
How to Open a Laptop Battery & Replace the Lithium Ion
Laptop batteries, like all rechargeable battery packs, lose their charging capacity over time. Because new Laptop batteries are expensive, replacing the individual cells inside the battery casing can save a lot of money. However, rebuilding a battery sometimes does not work as expected, so it’s important to be willing to purchase a new laptop battery if the procedure fails.
90-04208-003_original-hp-pavilion-dv8000z.jpg?w=250
HP Pavilion DV1100 Battery 12 cells
1、Allow the laptop battery to run down completely. Turn off your laptop, then remove the battery. Write down the model number located on your battery to help identify the type of Li-ion replacement cells you need to purchase.
2、Split open a small section of the laptop battery pack (at the seam) with a screwdriver or craft knife. Continue to pry the plastic case loose moving around the outer edge until the entire top is free. This may take a bit of force.
3、Note the number of cells inside the case (usually four to eight). Write down the part number and voltage information printed on the cell casings. Draw a diagram showing the arrangement of the cells and how they are connected, or take a few photos to help with reassembly.
4、Purchase the correct number and type replacement batteries from online shop such as udtek.com, based on your battery model and cell specifications. Six Li-ion cells typically cost around $30 to $40.
5、Carefully remove each cell using a craft knife and wire cutters as necessary. Each battery pack is different, but the cells are usually wrapped in a plastic casing with metal contacts attached to one end. Lay the metal contacts, wires and casing material aside.
6、Use double-sided tape or a solder gun (only if necessary) to attach the metal contacts to the cells and circuit board. When finished, the old cells should be completely stripped (naked) and the new cells should look like the old ones as much as possible.
7、Place the new cells inside the case, referring to your diagram or photos if necessary. Glue the battery(Compaq DV6000 Battery) pack top back on. Charge the new battery for at least 24 hours before using it.
Tips & Warnings
Keep an eye on the new battery while it charges for the first time. If the contacts are not connected properly, the battery could overheat and cause damage to the laptop.
on Feb 04, 2010 | Computers & Internet
Change battery in verifone 3730
battery is located inside the machine. You need to open the plastic case to see it. 7 screws holding the case together, but be careful not to break the case, multiple sensors inside the unit, don't loose it. If you still needs help, call us at (775) 358-2922 ask for Randy. http://freshpoint.org
Oct 05, 2012 | VeriFone Omni 3700
My Powershot SX10 IS has worked perfectly for 2 years. Recently I needed to change batteries, and since I did, (4 AA batteries), no matter how many times I put in brand new batteries of all brands, I...
First off, make sure that you're using good quality batteries, and not generic alkaline. Rechargeable NiMH are best. Next possibility is that not all of the batteries are making contact in the case. Make sure that the terminals at the bottom of the battery case haven't been bent low. If any of the batteries sit lower in the case than the others, try bending its bottom terminal up just a little bit so that it sits a little higher in the case, possibly improving its contact.
Aug 29, 2011 | Canon PowerShot SX10 IS Digital Camera
I need to replace the battery case for my Golden tech liteway scooter. Or i need to see a wiring diagram. Can you help?
This scooter requires (2) 12 volt 15 Ah batteries. Typically you would open the case and replace the two batteries inside not the entire case and batteries.
Locate the screws that hold the case together and open it. Make a diagram of the how the batteries are connected. Obtain the new batteries locally or on-line, install and fully charge.
Hope this helps.
Apr 24, 2011 | Golden Technologies Golden Liteway...
Is it possible to change the battery on the Technomarine 10900 at home (with the proper tools) or do I need to get it to a repair centre?
It is possible. Open the watch case back, memorize all the writings on watch battery as well as how the battery is positioned (+ and -). Buy exactly the same battery, replace it and close the case back. To be sure case back is closed as tight as it was, draw fine line across the case and case back with non-permanent marker. This will help you align when closing the watch and you can clean it off later. Rate me, please.
Apr 26, 2010 | TechnoMarine RSQC11 Wrist Watch
Battery doesn't charge anymore
Get your battery shipped from this reliable site and tell them that Abbas John Anari referred you to them. http://www.discount-laptopbattery.com/
This should help.
Regards
Feb 27, 2010 | Sharp Mobilon HC-4600
Nicad battery for makita want charge
For NiCd and NiMH batteries - check the battery voltage (for a good battery it is ~ 19, V); each battery contains 15 units 1.2 V each; you can test each unit after disassembling the battery case (my have 4 screws each, and the case has bottom and top parts). First charge the batteries; second, disassemble cases and check each unit voltage (shouldn't be less than 1.2 V); then take any battery tester (for AA, AAA and other batteries and accus for home usage), attach 2 long (~10 inches) wires to tester's testing contacts, and test each 1.2V unit for current - if it is in "yellow" or "red" zone - the unit is dead and needs replacement
Feb 16, 2010 | Makita 2 Bl1830 18v Battery,dc18ra Charger...
Cannot get into tomtom one v3
After the screws are out, just put something (I used a fingernail, but you might want to use something like a butterknife or a thin bladed screwdriver) between the silver front casing and the black back casing at the top front corner. Then gently pry until it separates. Do the same thing for the other top corner and the case should just pull loose. Be careful not to stress the cables connecting the speaker and the battery by pulling the back casing more than a few inches from the front casing (the battery and the speaker are attached to the back casing). The battery is held in place with sticky tape. Just disconnect the cable and gently pry it free from the sticky tape.
Mar 19, 2009 | Tomtom ONE 3rd Edition GPS
Don't know my BIOS password
New laptop store the password without requiring a continous power so removing the battery should not help in this case. Ask to your manufacturer for your password.
In some cases for example, like Dell laptops, the password will be given by customer support.
Thank you for using FIXYA
Dont forget to rate my help
Pablo :-)
Oct 15, 2008 | Compaq Presario V4000 Notebook
Master Replicas Star Wars Yoda Lightsaber .45 Scaled Replica Logo
160 people viewed this question
Top Master Replicas Toys Experts
Marvin
Marvin
Tom Chichester
ray gallant
Are you a Master Replicas Toy Expert? Answer questions, earn points and help others
