Question about LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive
My hard drive is clicking and the computer doesn't recognize it.
Posted by acirillo on
Andrea Lock
  • 6,831 Answers
Hello
OK, at the link below you will be directed to a tip i wrote on this exact error.
Click HERE.
Feel free to let me know if you have any further questions.
Kind regards
Andrea
Posted on Dec 02, 2010
5 Related Answers
xjr
SOURCE: Can no longer recognize my external hard drive
drive its ok, only electronic to the drive its death, you can buy cable and recovery your data
Posted on Dec 04, 2008
Anonymous
SOURCE: external hard drive
I just worked through this same issue with LaCie tech support and they fixed it- it was a bad power supply. Fortunately I had another LaCie drive and when I plugged the power supply from that one in to the "misbehaving" drive, everything booted up fine.
Posted on Dec 09, 2008
Lee
  • 393 Answers
SOURCE: Hard drive clicks several times when turned on,
I have to say from the sounds you describe the Hard Drive is totally destroyed, the noises you can hear are the mechanical parts inside grinding and clanking together. If the information is critical it may be recovered by a specialist data recovery company, but we are talking £100's even £1000's to do the job, so otherwise I would suggest taking case apart and buying a new hard drive for it.
Sorry its not what you want to hear but it sounds very terminal to me.
The reason the PC can detect a device is that it can see the Interface card that sits between the USB port and the Hard Drive.
Posted on Mar 03, 2010
Testimonial: "Thanks for a quick reply! "
Anonymous
  • 11 Answers
SOURCE: drive makes clicking and high pitched noise
The drive is probably dead and will have to be replaced.
Posted on Mar 14, 2010
bronk50
Brian Sullivan
  • 27725 Answers
SOURCE: computer wont recognize hard drive and drive keeps
the clicking noise is the reader arm jumping across platters on your hard drive you have a dirty hard drive first clean all the dust from your computer specifically from around your hard drive using a high powered sucksion vacuum cleaner or a fine air blower from a air compressor making sure there is no moisture in the air lines then give the hard drive a firm tap on the side to free it up
hope this helps good luck
the beeping sound is the post system searching for your hard drive and other connected devices
try replacing all the leads that attach to your hard drive including electrical extensions + IDE,SATA and the ones that attach from your motherboard to hard drive
make sure all leads that are attached to your drives dvd\cd 3 1/2 inch floppy have secure connections and are not faulty or just replace them they are probably old and faulty ?
good luck
Posted on Sep 13, 2010
My computer doesn't recognize my dane-elec 8gb usb stick , although other usb devices do work.
1. Try a different USB port. If other ports recognize it, then the original port is fried. 2. Try a different computer. If the other computer does not recognize it, then your flash drive is damaged.
Good Luck!
Aug 19, 2011 | Dane-Elec DaneElec 4GB USB Drive Copper...
My mac does not recognize my seagate goflex drive anymore
Try the drive on another computer. If it is recognized there, you might be looking at a larger issue on your Mac. If it doesn't, the GoFlex's drive or boards may have failed.
Jul 07, 2011 | Seagate 500GB FreeAgent GoFlex Hard Drive
I have 2gb verbatim flash drive.It worked fine when i first used but next time my computer recognizes it as a removable disk. After some hours i tried again and for some reason it worked. While i was...
click start control panel administrive tools computer management device manager scroll down universal serial bus controllers you should see a yellow question mark?
right click to reinstall drivers
if you can see your usb drive but its not working
ports(com&lpt)right click update driver if this fails to fix the problem
check the USB leads that attach to the motherboard usually red white green black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems for a computer and its parts
click start control panel administrive tools computer management disk management right click on your drive select properties click tools you should see click check now click start two boxes automatically fix files and scan for and attempt recovery of bad sectors place then a tick in both boxes then select check now start or you might tick one box then return after its finished the first repair then return and tick the second box you should not do anything while the chkdsk utility is in progress any input may damage this drive
click start click on my computer you should see your drive
right click then select format
another way is to control panel administrive tools computer management disk management right click on your drive select format
hope this helps
Jul 03, 2011 | Verbatim CORPORATION 94933 USB 2.1GB...
Loaded everything onto drive, now computer doesn't recognize drive when connected.
click start control panel administrive tools ,computer management ,device manager look through all of your devices if you see a yellow question mark?or exclamation mark ! or red x
right click to reinstall drivers or
if you can see your usb but its not working
sometimes the wires inside the cable will be damaged due to bending or stretching or placing heavy equipment upon the cable,
just replace the cable of the hard disk, when you plugged the external disk drive you got that windows could recognize the USB device change the cable everything should work fine again,
check the USB leads that attach to the motherboard usually red-white-green-black make sure they are securely seated and have no dust build up on them dust will cause static and a lot of unforeseen problems also make sure the computers Ram and Cmos battery are securely seated
hope this helps
Jun 25, 2011 | Iomega HDD Portable (32379) 30 GB Hard...
Installed 2T Hitachi drive with controller as secondary drive. Devices show both working correctly. But XP doesn't recognize it. How do I get XP to recognize it?
This problem can easily be fixed. It is caused by your HDD not being formatted. Go to Start> Right click on "my computer" and select manage from the box that pops up. In the window that pops up then, click on Storage > Disk management on the left hand side. Then right click on the drive you installed, and click format. You should probably format as NTFS.
Jun 17, 2011 | Hitachi Deskstar 5K3000 HDS5C3020ALA632...
Booted up my computer this am and the red light remains on and it does not appear that the system recognizes the external drive. The red light remains steady...I don't thhink the drive is running. How...
it is a known issue that these particular drives sometimes don't get recognized by the Operating System, after coming out of Sleep, Stand By, or Hibernation.
Simply try to disconnect and reconnect the drive again in the USB port, if this doesn't work then, Disconnect it from the USB and connect it to the Firewire. if this doesn't work then, Restart the computer.
It should solve the problem.
May 21, 2011 | Acomdata (HD080U2FE-72) 80 GB Hard Drive
Drive is not working. When you turn it on the blue light lights up but then goes off. The red light on the back stays on but the CPU does not recognize it. I have changed USB ports but it still doesn't...
please right click computer then Manager under storage, click Disk management. if you see you usb drive there, simply right click on it and format to exfat. fat32,or ntfs. if it doesn't show up, it pretty much shows that it needs an upgrade.
May 08, 2011 | SimpleTech SimpleDrive Pininfarina 320GB...
My old PC doesn't recognize my portable harddisks, I have several but really none.
with the drive connected, right click on "My Computer" and select manage, in the box which appears select disk management. You may be propted to initialise the disk, if you are, do so. If not, check for your drive in the lower panel and see if it has a drive letter, if it doesn't, right click on the disk and select change drive letter or paths, click add or change and select a letter from the drop down list. Click ok and now your drive should show in "My Computer"
May 03, 2011 | Transcend StoreJet 2.5 (TS120GSJ25T) 120...
CD driver do not read any file
Does it recognize any cd you put in the drive or is it only one cd it doesn't recognize?
Please check if the cd drive is recognized by your computer:
Click Start go to My Computer (XP) / Computer (Vista/Win 7)
and check if you can see the drive. (if it's not there you may have to reseat the drive to make sure that the cables connecting it to motherboard are tight)
check the status in the Device Manager:
On your Keyboard press and hold the Windows Key then press the letter R
once the Run box comes up type in devmgmt.msc and the device manager should appear.
On the device manager look for the cd / dvd drive see wether it has an exclamation point a red x mark or a down arrow or it looks normal.
if it has a yellow exclamation point press and hold the windows logo then the letter R again and type regedit:
On regedit go to HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Class\{4D36E965-E325-11CE-BFC1-08002BE10318} and the delete the upper and lower filters. Close Regedit and restart the computer.
if it has a red x mark right click on the cd drive in the drive in the device manager and the choose uninstall and restart the computer.
If it has a down arrow right click on the drive and click Enable.
If the above steps doesn't work or if it doesn't recognize all types of media you put in it, that might mean that your cd drive is busted and it needs to be replaced.
Hope you find this helpful!
Apr 30, 2011 | LG CRN 8245B (CRN-8245B) Internal 24x...
LaCie 500GB d2 Quadra 500 GB USB 2.0 Hard Drive Logo
60 people viewed this question
Top LaCie Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Marvin
Marvin
Michael Thomas
Michael Thomas
Are you a LaCie Computer and Internet Expert? Answer questions, earn points and help others
