Peg Perego John Deere Gator HPX Logo
Posted on Aug 08, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I am trying to refurb a John Deere 2510 and have no manual. The battery appears to be six volt but am unsure. What is the system voltage? Terry
Adam Fjeld
Level 3:
Genius:
  • Peg Perego Master 1,508 Answers
  • Posted on Jun 08, 2012
Adam Fjeld
Peg Perego Master
Level 3:
Genius:
Answers
1508
Questions
0
Helped
542667
Points
1761
For the toy it shoudl be a 12v
5 Related Answers
romney2012
  • 156 Answers
  • Posted on Sep 14, 2009
SOURCE: Please let me know how I can change the rear tires
My Grandkids go through these wheels every few years.
They love their Gator.
You take the center black cap off and use a socket to remove the attachment on the axle.
Here is the replacement wheels
http://www.shopjandl.com/sarp8115kny.html
They can also help you with the repair, I call them all the time..very friendly people.
hope this helps
Testimonial: "Thank you so much for the info. "
derik purlee
  • 110 Answers
  • Posted on Jan 28, 2011
SOURCE: What is the market price
a used gator in good condition should at least bring $100-150. it mainly depends on how it has been treated and stored. if its clean, good gearboxes and not faded, i would put it on craigslist for $150. there is a lot of demand for those, ive sold them in really bad cosmetic shape but working for $50 and in great shape with good battery and charger for $200. take a good picture and try and find the charger, that will add $
derik purlee
  • 110 Answers
SOURCE: where can i get a rubber tires for a Peg Perego
the whole tire would be difficult to replace with a rubber one, but you can put bmx tires on the plastic wheels and that will give much greater traction, but shorten the life of the gearboxes. here is a link to how to do it.
http://www.youtube.com/watch?v=AAySJVt6bys
derik purlee
  • 110 Answers
SOURCE: Where is the battary? Peg Perego John Deere Gator
the battery is behind the front bumper. There are tabs on either side in wheel wells to release the front end panel and it pivots downward to access the battery compartment. good luck!
Anonymous
  • 70 Answers
  • Posted on Mar 03, 2011
SOURCE: put a new charged battery in john deere and
It is most likely that you have a bad shifter switch, located under the shift handle. They can go out and do go out on people often. You can call their Tech Support which is excellent and will also walk you through if needed, you can also order the parts through them. 1-800-728-2108 or you can go to http://www.mypegperegoparts.com/asgi0115nyr.html to find the part
Where is the number one cylinder on a John Deere 2510 diesel
Front cylinder, see video, timestamp 1 minute.
https://youtu.be/4_-UAqbdBIE?si=R9JmVnZB64uONErP
I have a John Deere X595 and after mowing for about 30 minutes the deck cuts out but the engine keeps running can you assist please? Thank you
Check battery and charging system. Battery voltage should be >14 volts with engine running, >12.5 volts with engine off.
Deere Garden Open Question Battery not charging on a John Deere lt133 - John Deere Garden
Either battery has failed or charging system has failed. Try charging battery with an automotive battery charger. If battery takes a charge then trouble is in tractor charging system... likely the voltage regulator.
Have a John Deere hd45 hydro that keeps breaking the brand new ignition coil As soon as I install it will work fine fit after a while will just fail and won’t start again until new coil installed need...
Possibly a positive ground system, may be connected as neg ground system. OTHERWISE I WOULD LOOK FOR A SHORT IN THE WIRING. Is it a six volt or twelve volt system?
I need a wiring diagram for the air conditioner system on a 4440 john deere tractor. i am having trouble locating the source of power for the air conditioner compressor.
No luck finding a wiring diagram. Only thing was a complete factory service manual here - $87
JOHN DEERE 4440 TRACTOR SERVICE MANUAL TECHNICAL REPAIR SHOP NEW PRIORITY...
And the Clymer manual here - $35
John Deere Model 2510 4840 Tractor Service Repair Manual
If I were going to try to keep the 4440 going for as long as possible I'd go with the factory manual.
My john deere z445 won't start. makes ticking noise. what is the problem?
Confirm that engine will rotate.
Confirm voltage at battery during crank attempt minimum 9 volts at crank, 12 volts at rest.
Confirm greater than 9 volts at starter when cranking.
Model 170 with a Kawasaki 14 hp engine. Why doesn't anything happen when I turn the key?
This is a 12 volt system and the battery should have 12 1/2 volts. Motor running the voltage should be above 13 volts and below 14.5 volts. You will need a battery charge or jump start.
No spark to spark plugs on john deere 2510
do you have a bad wire or a bad wire going from the points to the coil
1helpful
2001 john deere 445 will not charge any common problems? How do you test the voltage regulator?
Voltage regulators will keep the voltage at around 13.5 to 14 volts with the vehicle running. This is what keeps your battery charged while driving the vehicle. If is lower than battery voltage (usually around 12.3 to 12.8) then it is probably bad.
John deere l11 weak battery had to jump off the last 4 or 5 times and this time hook up jumper cables and turn the key and get nothing. no lights no click just nothing. tried 2 sets of cables
Remove the old battery and clean the cables and battery posts. Hook a battery charger to it and fully charge the battery. If it will not hold a charge or the problem continues, replace the battery as it has shorted or dead cell. After replacing the battery or if the battery appears good and then runs down suspect the alternator is bad. Check the voltage at the battery with the engine running. You should have at least 13.5 volts on a 12 volt system and 7.5 volts on a 6 volt system.
Sep 12, 2009 • Garden
Top Peg Perego Toys Experts
john h
ADMIN Andrew
ADMIN Andrew
deton8 von Splosion
Are you a Peg Perego Toy Expert? Answer questions, earn points and help others
