Question about LG Electronic Window Air Conditioner
My ac is spitting out water in the front and making a loud noise
Posted by dameloc on
Anonymous
    Novelist:
    Champion:
  • 266 Answers
Your noise is probably your fan hitting water. First try to tilt the ac to slant to the outside. If this is done water should drain to the outside if not your drain hole is blocked from the front to the back you can see this if you remove the unit and look at the front coil housing you will see a very small weep hole clean it out and use a water hose to clean the front coil and the back coil. good luck
Posted on Aug 08, 2010
Anonymous
    New Friend:
Mine had something like lint and a beetle clogging the weep hole causing it to rattle and blow water out the front. I used a straw and a can of compressed air to clear the hole and let it drain to the back after that, the problem was gone.
Posted on Aug 26, 2010
1 Related Answer
Anonymous
  • 340 Answers
SOURCE: my 8000 btu a/c is spraying water out the front and making loud n
It needs to be taken apart and cleaned.Tom
Posted on Jun 20, 2009
Portable ac Danby Premiere DPA110CB5BP spitting water while it fans.
If you are referring to the unit doing this on the outside of the structure, this is normal. the "Hamster Wheel" is designed to carry a small amount of water and create a light amount of water to go onto the condenser to help with the evaporation and cooling process. If this is on the inside of the structure, the unit may not be level or another issue causing improper drainage.
Aug 01, 2017 | Danby Heating & Cooling
My unit is making a loud noise and is spitting water out with the cool air
i have had units turned too cold and ice forms on coils. shut unit down and take it out of window. turn /tilt and when all water runs out, re install and turn back on to a Higher , less cold setting.
Jul 29, 2012 | Hampton Bay HBLG5004 Air Conditioner
Window air conditioner is spitting water
Hello, usually a window AC will spit water if the unit is not tilted back or if the drain is backed up, if the unit is level try tilting it back it the window somewhat. Also, if the unit does have a drain make sure it is not blocked.
Jun 19, 2011 | Haier Hwr10xc6t Air Conditioner
Making a noise and spitting water inside
your ac unit may not be installed properly, it needs a 1/4 inch tilt to allow water to drain properly outside. Also make sure your drain plug is open to allow the water to drain out.
Apr 25, 2011 | LG Heating & Cooling
Ac making noise
sounds like the drain is clogged, it usually comes out if the outside of the unit just below the coil in the middle of the back, there may or may not be a hose attached to the front pan below the evaporator, try pressuring it up to blow it out. worst case you may have to remove from the window, disassemble and clean. hope this helps...
Jul 18, 2009 | Heating & Cooling
My haier a/c window unit is spitting water through the vent
Thermal transfer-the unit is creating condensation.
Jun 03, 2009 | Haier Heating & Cooling
AC is spitting out water inside. Where are the drain plugs?
I have the same AC and had this problem. Sludge builds up inside the bottom of the unit from dust and water build up causing it not to drain and the fan spits the water out. Its a fairly simple fix with a philips screw driver and a wet vac. Unplug the AC first. Remove the AC from the window. Remove the screw inside the front panel below the filter screen. Then you can pop the whole front panel off by pulling it with a little pressure. Now you need to remove the 3 screws holding each of the slider panels onto the side of the AC. Then remove the 3 screws on the bottom of the left and bottom of the right side of the AC. Remove the 3 screws holding the bar on top of the AC. Lastly remove the 2 screws on the back of the AC in the bottom Left and Right corners. You can now pull the top cover off. You can now use your wet vac to vacuum out the sludge that is in the bottom of the AC from the right and left side. There's a ground wire that connects from the fan motor to the bottom plate of the AC, be careful not to hit it. I knocked mine off possibly to it having been rusting in the backed up sludge and had to strip the wire and reconnect it.
Jun 02, 2009 | Heating & Cooling
Machine makes a loud wheezing noise just before
Mite have a broken gear in the fusing section (Hot Part) unplug machine and open **** shell and look to the left (if standing in front of machine) the left side rear is the fusing drive section check all gears also remove image unit and check gears
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
May 02, 2009 | Minolta Office Equipment & Supplies
Ac. spits out water in the front and ac., is tilted back ,gets worse as it runs
You need to blow into the drainpipe on the outside of the building to clear the blocked drainpan outlet. This just to make sure that your drain is clear. If the problem persists. Check that the filter is clean. This can also happen if you are slightly short of refrigerant and running the aircon at 18C or lower on a humid day.
Apr 28, 2009 | Heating & Cooling
LG Electronic Window Air Conditioner Logo
9,749 people viewed this question
Top LG Heating & Cooling Experts
Marvin
Marvin
Steve Oakes
Steve Oakes
Muntejaya Ginting
Muntejaya Ginting
Are you a LG Heating and Cooling Expert? Answer questions, earn points and help others
