Question about Kingston (DTIU3/2GB) 2 GB USB Hard Drive
How can I retreive my files from a kingston 4GB DataTraveler
Posted by bnellp on
Brian Sullivan
  • Kingston Master
  • 27,725 Answers
Plug the 4kg data traveller it into a USB port open windows explorer open the data traveller select the files copy and paste into my documents on your computer
hope this helps
Posted on Aug 08, 2010
Why in my pendrive all the data we trancefer are come in shortcut
Probably you just copied a shortcut to the location of the files. You need to go back and verify whether this is the case.
Oct 05, 2014 | Kingston Digital 4GB DATATRAVELER C10...
Datatraveler g3 driver
go to start , RIGHT CLICK on My computer the select manage.
In the window that will open choose manage disks and reformat your usb stick (if it's not shown there connect it into another port and repeat )
May 13, 2013 | Kingston 4GB DataTraveler I Generation 3...
How do i format the kingston datatraveler 310 256 gb to ntfs file system
Hello insert the drive in the usb port.
When you see the drive in the control panel, right click on it and choose format.
Select NTFS in the selection box, and mark quick format and click start.
This could take a while.
You just have to save ALL the previous saved files, before you format, because the files will be lost, when the the drive is formatet.
Good luck
Mar 04, 2013 | Kingston DataTraveler 310 DT310/256GB...
Where can I get instruction on how to use your 4GB DataTraveler - G3 - USB 2.0 ?
Hello Gwolk,
The Kingston 4GB DataTraveler Generation 3 (G3) USB 2.0 is a durable 4GB flash memory drive for use with both Macintosh and PC computers. It may be used to transfer files from one platform to another, or to carry files and small applications on a continuing basis. Having no moving parts, flash drives are exceptionally durable and reliable for years of use.Simple - just plug into any USB port
Aug 16, 2011 | Kingston Digital 4GB DATATRAVELER C10...
I'm having kingston datatraveler 120 4gb .It is
Check the USB on another PC and if this is not detected on any PC then the memory is corrupt.
In such a case there is not much unless the dealerships helps for a replacement.
Jul 11, 2011 | Electronics - Others
KINGSTON 4GB USB DataTraveler Mini Slim
What is the issue that you are having with your Kingston 4GB USB DataTraveler Mini Slim?
Mar 01, 2011 | Cell Phones
My datatraveler 64gb dont formating in my
datatraveler dti.4gb ""the disk in drive E is not formatted" how to solve my problem
Dec 17, 2009 | Kingston (DTIU3/2GB) 2 GB USB Hard Drive
Kingston Datatraveler 2GB Failure
Try formatting the drive. Should be a problem with the file system.
Jul 26, 2009 | Kingston Technologies 512MB DataTraveler I...
My ped drive kingston datatraveller 4gb doesnot work in win98
I think you will find that the card works fine but your computer doesnt recognise the card reader properly. Windows 98 does not properly recognise most usb devices but Windows 98SE does although I am not sure if it will recognise usb2 properly.
Jun 04, 2009 | Kingston 4GB Secure Digital High Capacity...
DataTraveler 4GB
You can use with Windows2000 and up and other operating system, you ca check this link for the complete information about this device http://www.kingston.com/ukroot/flash/dt_secure.asp?id=2
Hope that helps...........
Oct 01, 2008 | Kingston Technologies 512MB DataTraveler I...
Kingston (DTIU3/2GB) 2 GB USB Hard Drive Logo
157 people viewed this question
Top Kingston Computers & Internet Experts
ChinthakaJ
ChinthakaJ
Mike
Harish  Ramaiah
Harish Ramaiah
Are you a Kingston Computer and Internet Expert? Answer questions, earn points and help others
