1999 Chevrolet Astro Logo
Posted on Aug 08, 2010
1999 Astor van won,t start. its not the battery
Anonymous
Level 1:
New Friend:
Problem Solver:
  • Contributor 6 Answers
  • Posted on Sep 09, 2010
Anonymous
Contributor
Level 1:
New Friend:
Problem Solver:
Answers
6
Questions
Helped
2490
Points
8
Had same problem ignition coil was defective replaced ok
How do I replace a map sensor on a 1993 chevy astor van
it's under the interior cover , it need to come out, then the MAP is to the right of the radio ...it looks like this. hope this helps fd91761c-53b1-46cc-83c4-174504cbc0c0.jpg
Van won't start,rapid clicking heard when key is turned. need help/directions replacing starter relay for gmc vandura 2500, 1991
Check battery connections and battery fuse. Battery may not be large enough for the size of your van
1999 Chevy astro van won't start
Had the same issue with our 1999 chevy astro van, would crank but would not start. It had been raining and windshield had a leak, after 2 days of no rain it started. Pulled codes and was the Security system in the ignition switch. Hope this helps.
2answers
Van won't start brand new battery,but acts like a
CHECK THE MAIN FUSES, ON THE FRONT,, AND THE BATTERY CABLE.... YOU CAN REQUEST A SERVICE REPAIR MANUAL FOR FREE AT BESTDIRECTORYSOLUTIONS.COM
2002 Astor Van will not start it turn over fine . I checked the fuses under the hood and the panal all where good.But I am not hearing the fuel pump on it when I turn the key to the on spot.
Did you check the fuel pump fuse? It's often all by itself, and not in the fusebox. This is the case on Chevy/GMC C/K trucks, it might be similar on the Astro van.
99 windstar van, won't turn over,won't start, headlights won't turn off,
baterr ywas dead changed it-new battery worked-discharged once air turned on-put in 2nd bateer yseems fimne as long as you don't turn on the air-if you do there is a clicking inside radioconsole and discharges battery
1999 Dodge Ram Conversion Van won't start. After many attempts the battery finally died but before it did it was making a clicking noise when we tried to start it. My husband saw a spark under the...
I hope that you have disconnected the battery fire could happen relay click's but will stick at drain could be the fuel pump you hear with the continuse click you might have a shorted starter.I think thats the first place to start.A bad ignition switch will cause this to happen sometimes?
What is the spark plug gap for a 1989 chevy astor van
Depending on what motor you have.The 2.5 is 60 thousands and the 4.3 is 35 thousands.Hope this helps.Good luck.
1helpful
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
