You only need to read my tip to be able to recover your iPod from that state. Check it out from the link below:
http://www.fixya.com/support/r5541493-put_iphone_ipod_touch_dfu_mode_restore
For more iPhone / iPod touch tips like jailbreaking and unlocking, click here.
If you need online help about jailbreaking and unlocking, you can contact me personally at this email: [email protected]
"iPod is disabled - Connect to iTunes" . This is because someone(or something?) has tried to crack your password too many times, which causes Iphone/Ipod to automatically disable itself to protect your data.
To restore your iPod, you must connect your iPod to iTunes with your iPod connector table. Make sure it is on and has this message when you connect it to your computer. Once connected, iTunes should detect it as usual.
Once connected, make sure you have all the proper sync settings enabled - for example, applications, music, photos, etc. Change something so that the Sync button in the bottom right appears in the iTunes window. Then sync the data.
When syncing is finished, turn on your iPod / iPhone and you should notice that the message is gone. Type in your password and the disabled message should be gone.
If the message is still there, try holding the sleep and home button at the same time until the iPod turns off, then continue holding the sleep and home button until a screen with the iTunes logo and a picture of the connector cable appears. This will put your iPod in Restore mode. With this option, you must click the Restore button in iTunes, which will delete all your data on the iPod.
