Question about Goodman CPLE24-1 Air Conditioner
Where is the fuse/breaker on a goodman cple 18-1
Posted by dstevens453 on
Robert Horton
  • 1,515 Answers
Hi, I wanted to look up the numbers you gave me as you listed 2 different model numbers, the CPLE-18-1 is a 1&1/2 remote condenser and the other you showed CPLE-24-1 is a 2 ton unit. Doesn't matter, but if your power was lost you have your main breaker box at your meter, and at the condenser you will have a disconnect box with a pull out type plug. If you see no fuses, try removing the plastic cover as they are required to install 2-fuses in side the box also. If this is a split system with the outdoor and indoor unit, you will also have a breaker inside for the indoor unit, its high voltage and you will have a circuit board in the indoor unit with a 3 to 5 amp auto type plug in fuse.
I hope this has helped you out on this. I will be here if you have more questions. Please do not forget to rate me as I know you will be kind. Keep me posted.
Sincerely,
Shastalaker7
A/C, Heating, & Refrigeration Contracted
Posted on Aug 08, 2010
What cause 3 amp fuse to keep blowing when power in turn on goodman air handler
The 3 amp fuse is in the red low voltage (24 volt) thermostat wire
and only gets power when the thermostat is set to turn on heat or a/c It should be connected to the red wire from the thermostat
Nov 13, 2014 | Goodman Manufacturing Goodman ARUF48D14...
What could be wrong with my Goodman CPLE 42-1.
Have you checked the wire terminals at the compressor. They tend to get very brittle and burn up rather frequently. Have you checked for voltage at the compressor terminals once the relay closes? If you have 220V at the terminals its working properly, most likely your compressor is shorted. Pull the wires of the terminals and check their resistance/continuity. If they are OK check for a short between the housing and each terminal, there should be no circuit to ground at any terminal, if there its shorted, need a new one.
Aug 10, 2014 | Heating & Cooling
Where is fuse for 5 ton goodman package unit heat pump
Im assuming you mean the low voltage fuse? In that case its located on the circuit board inside the electrical panel on the unit. If looking for the high voltage fuse (breaker) you should have a disconnect outside protected by a breaker inside at the electric service panel (breaker box).
Travis--
Mar 25, 2014 | Goodman Heating & Cooling
How to fix a capicator for a goodman cple-42-18 air unit
The capacitor must be replaced if not working. They are not made to be repaired.
Jun 03, 2012 | Goodman Heating & Cooling
Goodman ac unit won't come on at all
ALSO CHECK FUSES IN BOX ON OUTSIDE WALL . SHUT OFF BREAKER BEFORE FUSE CHECK. BREAKER MUST BE TURNED ALL THE WAY OFF THEN BACK ON TO RESET
Apr 20, 2010 | Goodman CLQ36AR49 Air Conditioner
Goodman unit blows 45 amp fuses only in heat mode, worked fine all summer on a/c. It works well for some time then blows them again.
Check the breakers on the unit How many KW--electric heat? Check to see if you have the right wires wired up to the correct breaker cause some units have 40---and ---60 ---amps breakers and your thickest wire could be wired to the 40-amp breakers,, (some 5 KW pullls 19-23 amps respectably some breakers have 7.5 KW heat stips and pulls more and if the wire size can,t cary the amps, then all you have to do is reduce a heat strip.
Dec 18, 2009 | Goodman GMS90703BXA Heater
Normal in cool cycle, very high pressure in heat cycle
Expansion valve on the condensor or possibly overcharged with refrigerant?
Nov 01, 2009 | Goodman Heating & Cooling
Heating & Cooling Logo
206 people viewed this question
Top Goodman Heating & Cooling Experts
Paul Carew
Dennis Boxerman
jdthefixer
Are you a Goodman Heating and Cooling Expert? Answer questions, earn points and help others
