This Maytag is about 9 year old and I've probably already sunk too much $ into repairs. Newest problem just happened today.
Loud banging noise during spin cycle and later discovered water leak. Took back off and ran a short spin and water appears to be coming from where the spider arm attaches to the drum. Likely problem? Worth getting repaired? Thanks.
SOURCE: kenmore front load washer #44072 drum banging noise
I have the same problem...the solution is called new washer. I was told it could be overhauled to the tune about $600...barrings are going out. Mine is just 7 years old and that's disappointing.
SOURCE: Loud banging noise during final high speed spin
I have the HE3T which is 6 yo. Last week it started making a loud banging noise in the spin cycle. I had a repairman come out. He said it is the drum bearings. He said that it is a problem with these machines and to call Sears. He said that the drum and bearing is one assembly and that Sears should cover it.
I called today and Sears todl me that I have to pay for a Sears technician to come out a determine if it is indeed the problem. If so, it will be covered under the lifetime warranty on the drum. I have to pay for the service call $75.00 and if it is the problem, I will be reimbursed. Cross my fingers!
SOURCE: Fisher Paykel Gw11, leaking, loud noise, not going through cycle
pump is a common fault and easy to change for about $25. all sound related. new machines are pretty inexpensive. your call
SOURCE: Washing machine is leaking water out of the bottom
Leak could be a few things, Pump depending on what side its on /bangs, are they electrical ?
SOURCE: front loader making loud noise with spin cycle
i have the same problem as urs. i open the whole drum myself and replaced the rear bearing. but the actual problem is the bearing housing is loose in plastic drum. so only drum needs to be replaced.
