Question about Vision HDV-42P2 Television
I was home watching television while we were having a thunderstorm out, there was lighting and thunder and it was pouring out, the power went out so did the TV. I can power up the TV you can hear it power on but the screen is blank not black but blank. The little red button lights up but the screen once again stays blank.
Posted by deeortiz217 on
Don Eagan
    Master:
  • Vision Master
  • 714 Answers
You may have fried one of your control boards in your TV. Sometimes these can be easy to fix. I recommend you take your unit to a repair shop and get a quote to repair it. Be sure to get a quote and don't just tell them to repair it. It may be cheaper to buy a new TV! Sometimes they will charge you just to troubleshoot your TV but that should be expected.
Posted on Nov 28, 2017
1 Related Answer
Anonymous
  • 72 Answers
SOURCE: 42" samsung plasma screen cracking on
i would say take it to your local tv repair shop the screen will have to be replaced or if you told your insurance i happened because of a lighting storm they might have replaced it
Posted on Aug 08, 2009
How do I fix my Vizio Television after a thunderstorm?
You TV was victim of power surge. You should take it to a qualified repair service to diagnose it, it it it can be repaired and if it's worth.
Curren flat panel electronic TVs are particularly sensible to power surge so it might be a good investment to use spike protectors.
Browse here
Top Rated in Surge Protectors
Jun 20, 2015 | Vizio E371VL 37 Class LCD HDTV - 1080p,...
Is there a reset button on tv? tv went out in a thunderstorm last night and will not come back on.
Hi Anne,
It is not a case of reset. The power supply section of your TV is damaged in the thunder storm. It is a common thing happening to TVs. Yes, sometimes, if you are lucky you escape with small damage like fuse and a few safety components. Otherwise you may have to replace the entire power board. Please consult some local TV tech,
Good Luck.
May 28, 2015 | Televison & Video
HELP! I think my TV got zapped and is ruined from storm!
Check whether the power outlet has power. If it has, I suggest please do not attempt to switch on the TV, unless checked by a qualified service technician.
Aug 16, 2012 | Toshib 46L5200U 46" 1080p LED-LCD TV -...
Thunder storm last night
have u made sure that the out let has power yet? if not check fuse box.
next, if has power to outlet, manually press power button not remote controll, after it has been unplugged for some time. view the back pannel of tv. and see if there is a fuse or fuse notification. follow manufactuar or owners manual instructions from here, google vizio support or call 888 849 4623 with model and info ready
Jul 13, 2012 | Vizio VW32L 32 in. LCD HDTV
Can a thunderstorm cause a tornado then?
Well yes it all depends on the thunder storm type like heavy thunder storms have a higher chance or creating a tornado compaired to light thunder storms and also it needs the right amount of humidity to run and the hot and cold air mix toghter too.
Mar 23, 2011 | Nintendo GameCube Console
Why do thunderstorms have heavy rain with them?
rain and thunder are two peas in the same pod. thunderstorm clouds also known as cumulonimbus are generally the clouds we know as rain bringers.
as water molecules rub together they creat static electricity. this is then discharged as lighting. the thunder you hear is the sound waves made by the lightingin caused by the water molecules.
so water rubs and makes electricity which makes thunder which is why thunderstoms have rain!
Mar 23, 2011 | Nintendo Wii Console
I have the sanyo dp46848 it 3 months past warranty , we had a thunderstorm ,my wife turned off the tv but we did not unplug it. when the storm was over we turned it on and all we got was a led power light...
It can be the main logic board EPROM is scrambled since the TV was plugged during the thunder storm, and /or the power supply module are damaged.
You will have to do more in-depth troubleshooting.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Please post back what you find.
Jul 21, 2010 | Sanyo DP46848 LCD TV
Tv turns on and then off
Good Day, ruschracing;
Storm? The first thing you should do is unplug the TV from the wall for 3 to 6 minutes (reset), then plug back into wall.
If that does not help, then you should call an authorized service center to give you an estimate for the repairs. OR call your home owners insurance company.
Good Luck, big IRISH.
Jul 25, 2008 | Hitachi UltraVision CineForm 55VG825 55"...
Televison & Video Logo
43 people viewed this question
Top Vision Televison & Video Experts
Marvin
Marvin
ray gallant
Are you a Vision Televison and Video Expert? Answer questions, earn points and help others
