Norelco 7886XL Electric Shaver Logo
Posted on May 15, 2017
Norelco 7886XL shaver battery replacement problem
After replacing the Ni-Cad batteries in my shaver (unsoldering the tabs that were soldered to the circuit board, resoldering the new battery tabs to the circuit board), I found that the shaver won't turn off when connected to the AC power supply / charger. The shaver keeps on running if the cord is connected, no matter what I do with the switch. The switch appears to be working, and the batteries appear to be getting charged. Did I fry a component? Is this fixable?
Thanks.
Mark
  • Make it work May 14, 2008
    I didn't replace the batteries, but I have the same problem. When I press the on/off switch, the razor keeps running for about a minute. After the batteries were eventually discharged (somewhat prematurely) the razor would no longer turn on after I recharged it, or even when I plugged it in.
    There are no visible problems on the circuit board or other connections to it. The gear train appears to be free from restrictions.
5 Related Answers
Anonymous
  • 91 Answers
  • Posted on Jan 07, 2009
SOURCE: replacing batteries in a 6705x norelco shaver
To open up your shaver, remove the lotion cover and remove all 5 screws with a small flat head screwdriver. They have a star head, but also a flat notch. Since they shaver is water tight, the first time you open it up it will be difficult, but if you pry off with your screwdriver it should pop off.
Towards the head of the shaver the batteries are soldered to the circuit board. Pull the tail end of the batteries out of the plastic holder and cut them at the top end as close to the batteries as you can, or CAREFULLY bend it back and forth to snap the metal. Dispose of the batteries responsibly as you would any batteries.
Hope it helps you.
VtToolMan
Mark
  • 704 Answers
  • Posted on Sep 03, 2009
SOURCE: Replacing batteries in Norelco Razor 7886XL
Chris, All rechargable shavers have their battery(ies) soldered to the main circuit board inside the razor. In order to replace the battery(ies), you will need to disassemble the shaver by carefully removing the molded plastic cover(s) that hide the screws (which hold the shaver together). Sometimes located under the shaver head on certain Norelco models, others are under pressed in covers on the back and/or front.
Once you've done that, you have to be very careful not to dislodge any of the mechanical connections from the motor to the cutting heads. With the board exposed, you'll see the batteries, soldered to the circuit board via tabs that are heat staked to the batteries. Note which way the polarity (+ or -) are located on the board. Take a digital picture to make replacement and reassembly easier when you're putting everything back together.
Now with a pre-heated soldering iron, melt off the solder on the battery terminals and remove them quickly. Do not heat the tabs any longer than needed, so as to avoid possible damage to the circuit board. With the batteries removed, you might have to open up the thru-holes where the battery tabs go in, in order to get the new ones in place. Solder them into place and you're almost done.
Now reassemble the shaver and allow the shaver to recharge for at least 8 hours.
If you have any doubts about doing the repair yourself, you can have the shaver repaired by a service in Nebraska that specializes in replacement parts and service for all brands of electric shavers.
http://www.electricshaverstore.com/
They usually can turn around a repair in a week from reciept.
Hope you find this Very Helpful and best regards!
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Jan 16, 2010
SOURCE: after soldering new batteries my shaver´s on-off switch won´t wor
it sounds like you may have some sloppy solder which is causing a continuous connection here there shouldnt be
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Apr 23, 2010
SOURCE: I opened up the case to my Norelco 5601X to replace the batteries
For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find batteriers for your model 5601X shaver at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-battery-pack-for-most-norelco-more-p-278.html
brector3
shaveroutlet.com
  • 1652 Answers
  • Posted on Sep 09, 2010
SOURCE: what kind of head is
You will find heads and batteries for your shaver st shaveroutlet.com. See links below
http://shaveroutlet.com/norelco-philips-hq4-plus-replacement-heads-also-fits-eltron-p-248.html
http://shaveroutlet.com/shaver-battery-pack-for-select-norelco-remington-p-214.html
2helpful
I NEED STEP BY STEP INSTRUCTIONS TO REPLACE THE Ni Cd BATTERIES ON A SPECTRA 8865 XL SHAVER
You will find the correct battery type for model 8865XL at shaveroutlet.com. See link below.
http://shaveroutlet.com/shaver-replacement-parts/shaver-battery-pack-for-most-norelco-more-p-278.html
To replace, you will need to remove the back cover by removing the two screws. You may need to extend the long hair trimmer to get to the second screw. Take off back cover to access inside. You can unsolder the batteries from the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries with small needle nose pliers rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, you can have shaveroutlet.com do it for you. See link below
http://shaveroutlet.com/shaver-replacement-parts/professional-battery-replacement-for-most-models-p-374.html
2answers
I NEED HELP REPLACING THE NI-CAD BATTERIES ON MY SPECTRA 8865 XL
1helpful
How do I remove the batteries from a Norelco 4605x razor ?
Remove the 4 screws on the back to take off the back cover. You will have to extend the trimmer to access 2 of the screws. You can then unsolder the batteries from the circuit board.
If you are replacing the batteries, for easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
You will find replacement batteries for model at shaveroutlet.com. See link below
How do I change the batteries in my 6885XL razor
You will find the correct battery pack for this model at shaveroutlet.com. See link below
Remove the two screws on the back to take off the back cover. One of the screws is hidden by the trimmer so you must extend the trimmer to see it. Once back is removed, remove the metal clip at the bottom end of the batteries. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Soldering is required to replace the battery pack. If you are not capable of soldering in the new batteries, you may want to consider buying the item below instead for easy installation
http://shaveroutlet.com/philips-norelco-7886xl-quadra-shaver-lower-unit-part.html
2answers
Battery replacement
The batteries are soldered to the circuit board. They do not simply pull out. The batteries can be unsoldered from the back of the circuit board but for easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
you will find batteries at shaveroutlet.com. See link below
1helpful
I opened up the case to my Norelco 5601X to replace the batteries. It looks like the batteries are soldered to tabs that go through to the other side of the circuit board. I can't seem to see how to lift...
Won't hold a charge
You will need to replace the batteries. For model 7886XL, you will find batteries at shaveroutlet.com using the link below
To replace, remove the two screws on the back to remove the back cover. For easier replacement, it is sometimes suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
If you are not able to do this yourself, shaveroutlet.com can do it for you. See link below
http://shaveroutlet.com/professional-battery-replacement-for-most-models-p-374.html
10helpful
3helpful
2answers
How do I change the Battery in My Norelco T3000 Beard Trimer
Remove Phillips head screw at bottom of trimmer. Separate body in two being careful to notice how on/off switch is assembled. Unsolder the ni-cad battery from circuit board. Install new ni-cad battery of the same physical size that has solder tabs on it and solder it to the circuit board. I used a ni-hi (nickle metel hydride) instead of ni-cad which had different charging requirements so I limit charge time to no more than 16 hours for a discharged battery. It had been working fine for over a year. Don't forget to apply a few drops of light oil to the cutting blades to extend cutting life. Replacement blades are about $30.00
Top Norelco Health & Beauty Experts
ADMIN Andrew
ADMIN Andrew
Thomas Perkins
Thomas Perkins
Kardoc
Are you a Norelco Health and Beauty Expert? Answer questions, earn points and help others
