Question about Kenmore 98702 Stacked Washer/Dryer
Neighbor has stackable dryer Kenmore. trying to figure out how to install new belt. one we have seems too big as it spins when turned on. we installed the belt around the drum then around the two pulleys. one mis spring loaded the other the motor pulley. what are we doing wrong? model #417.99370120
Posted by lretcop1 on
vince
  • Kenmore Master
  • 1,234 Answers
Not sure but go here...
https://www.repairclinic.com/Shop-For-Parts/a17b6c7i920d183467/Model-41799370120-Kenmore-Washer-Dryer-Combo-Belt-Drive-Belt-Parts
check if the oem # match what you have. if it's oem.
there's a video on the second belt on the list that might help you
hope so.
Posted on Jan 23, 2018
  • vince Jan 23, 2018
    woops that model # came up as a washer.
5 Related Answers
catriver
Ron Marek
  • 878 Answers
SOURCE: How much play in rear pulley
Scott, the pulley should be tight, no play, Check to see if one of spokes are cracked on the pulley. I do believe that you have a 5 year warranty on the bearings on this machine, parts only. It's a huge job to replace the bearings on this model. Give Sears a call to see if they will cover the parts. You will need the rear tub and bearing kit...Good luck
Posted on Jun 21, 2006
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: agitated with my agitator and spin cycle
Your problem could be with your transmission, which is located directly above the drive belt pulley under the wash tub. If they go bad, your motor will still function normally, but the wash tub will not spin or agitate. Now, another possible problem could be a nail or screw stuck in one of the wash basket holes pressing against the outer tub. I have personally seen this a couple of times. A dry wall screw or nail will stop the wash tub from spinning and cause the drive belt to smoke as the motor pulley turns, but the belt stays stationary. That could be the source of your smell. If you're a do-it-yourselfer or do a lot of carpentry work, you may have washed some clothes with a nail or screw in them. Inspect all the holes in the wash basket throughly. A nail or screw can easily be missed if your not looking for it. I hope this may help you.
Posted on May 04, 2007
jsrock516
Jeff Rockwell
  • 5911 Answers
SOURCE: Kenmore h3 won't spin
Remove the pulley nut and pulley. The pulley should have a round hole with two flat sides that ride on a shaft. If the flat sides of this opening are damaged the pulley will not stay tight and will rattle. Try tightening everything down. If you can grab the pulley (like a steering wheel on a car) and turn it back and forth on the shaft, there shouldn't be any "play" in it. The whole drum should turn. If this is the case, replace the pulley and nut. I hope this helps you.
Posted on Jul 31, 2007
the dr
joey shearer
  • 447 Answers
SOURCE: replacing belt on Amana LWD70AW top load washing machine
There is a post for this in my solved solutions. If you cant find [email protected]
Posted on Jan 10, 2008
Anonymous
  • 1937 Answers
SOURCE: I have a top loading Kenmore 80 series Model #
This assumes that you have a basic Kenmore / Whirlpool top load, direct drive, neutral drain (it doesn't spin until the pump removes most of the water) machine.
First, see the Sears parts site for your washer:
http://www.searspartsdirect.com/partsdirect/index.action
Enter your model number and you'll see a list of major sub-components with diagrams and parts.
The Kenmore / Whirlpool top load uses a reversing motor to initiate the pump for draining and the transmission to spin.
If you cannot hear the motor trying to turn the pump, (but the washer will agitate) the problem points to the Timer, or the Lid Switch.
Try to bypass the Lid Switch by removing the Console and jumping the two outermost pins on the switch.
This is the Whirlpool PDF on installation and maintenance of direct drive washers. See the section on how to bypass the lid switch and on the transmission.
WHIRLPOOL INST AND MAINTENANCE INCLUDING HOW TRANSMISSION WORKS
https://secured.whirlpool.com/Service/SrvTechAdm.nsf/2cd44500d572193285256a45004fd9d6/f7e2147fa98b28cf85257122007475cb/$FILE/L-55.pdf
If everything else works OK,, including the drain, and the timer moves, the problem could be in the transmission / gearcase.
If you lift the lid, put it down again and the washer begins to spin, the problem is likely in the transmission "Neutral Drain Assembly".
Those cams/gears etc. in that assembly keep the washer from spinning until all of the water is pumped out and then go into spin mode. Apparently, by opening and closing the lid, torque from the motor starting throws the cams into the right gears so that the washer will spin.
Ours had the same problem, no spin unless the lid was raised and lowered or we shut off and re-started the cycle.
After looking at the transmission parts list (available on a number of sites) and on the Whirlpool site (Whirlpool makes Kenmore) we noticed that the one of the cams in the neutral assembly which is supposed to have a small spring, didn't on ours when we tore the transmission apart again. The Sears site for your washer may have a sub-component section on the gearcase with a part number for the Neutral Drain Assembly repair kit.
http://shared.whirlpoolcorp.com/assets/pdfs/literature/Repair%20Part%20List%20-%20W10114743.pdf
Found the part number for a kit (Whirlpool part number 388253 Neutral Assembly) for $15.00 and replaced the cams and gears.
In order to get the transmission out, you have to remove the cabinet, the fabric dispenser and both agitators. The top agitator uses a plastic 1/2" drive bolt. You don't have to remove the drum.
You can also see this site for removing the transmission.
http://www.fixya.com/support/r699497-replacing_gearcase
Lay the machine down (after disconnecting power and hoses, remove the pump (two clips), the motor (two screws hold two clips on the motor), lift and set the motor aside, remove two 1/2 inch bolts for the motor mounting plate and three 1/2 inch bolts for the transmission. Pull the transmission, remove the clutch (there is a spring clip that holds the clutch on the main agitator shaft, remove the 8 screws carefully the transmission holds 14 - 15Oz of oil, remove the clip holding the main spin gear on and check the plastic cams.
If the cam that should have a spring doesn't, or the others look damaged, the washer won't go into spin mode.
If that's the problem, install a Neutral drain kit, put everything back together carefully and the problem may be solved.
With ours, all told, it cost less than $30 (including new 80-90 weight gear oil) vs. about $170 for a new transmission.
The job is a bit complicated and messy but not too difficult.
Posted on Sep 29, 2009
Testimonial: "The information is very detailed and I'm sure will be helpful. We'll know more once we check for damages to the springs on the cams."
Kenmore stackable wash/dryer Dryer squeaks so loud. How do I stop the squeak.
You probably have a bearing in one of the rollers that spin when the dryer is turning. You'll have to take the front panel off and remove the dryer tub by taking the belt off. You'll then see two doughnut shaped wheels attached to the back panel. Check and see if one or both are loose on the shaft that holds them. If they are replace them. Lubercating is not an option. If they seem ok, check the wheel that the belt loops through and make sure it spins without wobbling. One of the three things is causing the squeak.
May 18, 2014 | Dryers
The drum in my Kenmore gas dryer (over 20 years old) will not spin around. There is still heat, but clothes will not spin around. Does the belt need to be replaced or should I get a new dryer altogether?...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor going bad...
Here are a couple of tips that I wrote will help you to figure out why your dryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
Apr 18, 2011 | Kenmore Dryers
Hello. My kenmore dryer 65751 has stopped spinning. I can hear that the motor is getting power but it seems that the spinning mechanizm has seized up. Also looked at the belt and is seems fine.
Dryer Repair - The
Dryer Repair - The
heatman101
Dec 24, 2010 | Kenmore 67751 Electric Dryer
Dryer will not start, just humms
sounds like the drum belt maybe broken or worn out.
May 25, 2009 | Kenmore 98702 Stacked Washer/Dryer
Stackable washer/dryer
hi..
When your dryer drum isn’t turning anymore, it’s usually a broken belt. Tearing the dryer apart is usually straight-forward enough but stringing the new belt on the motor and idler pulley can be tricky. The Complete Encyclopedia of Dryer Belt Configurations shows the belt configurations for almost every dryer brand you can think of.
this will fix ur problem..
thank u rate me
May 25, 2009 | Kenmore 93702 Top Load Stacked Washer /...
How do I install new belt on Kenmore stackable #41789390800
look in the console - or inside the dryer shell for the service manual. All wiring diagrams are in the service manual.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 26, 2009 | Kenmore 98702 Stacked Washer/Dryer
Belt and assembly trouble. Please help!!
Yes, there is a tension pulley but I"m at a loss as to how you're burning the belt, if not routed around the tensioner... seems to me you'd have a world of belt slack.
You might check and see if you can freely spin the drum, or if it seems to be locked-up. There may be an obstruction, keeping it from rotating... it shouldn't require so much effort.
Just a suggestion... Good luck.
Mar 05, 2009 | Kenmore 62722 Electric Dryer
Kenmore 98702 Stacked Washer/Dryer Logo
136 people viewed this question
Michael Thomas
Michael Thomas
Paul Carew
Nicola Conroy
