Question about Avanquest Nitro PDF Professional
I edited a pdf, making onscreen small changes, and added comments using sticky notes, but found that the file size had increased for 1.5MB to a massive 37MB at the end of the exercise! It seems to be the editing function which increased the size rather than the reviewing. Any idea whay and how to avoid? Thanks!
Posted by ann_nigel on
ray gallant
    Top Expert:
  • Avanquest Master
  • 69,263 Answers
Yes DO NOT EDIT PDF's
Posted on Dec 24, 2017
Make font larger on HP1510 printer
What font are you referring to? Have you prepared a document in a word processing program, or added text to an image file, and are disappointed because you want to see the text printed larger? If so, your best solution is to edit the document or image and change to a larger text size. For example, most text documents will normally default to either a size 10 or 11 text which is readable but small. Changing to size 12 or 14 will make the text look larger onscreen, and the text will also print larger. The font name and font size should be displayed on one of your processing program's toolbars, and is easily changed to a different font name or size. If you are simply copying an already printed document and want the text to appear larger, you should refer to your printer's User Guide. If you don't have the User Guide, you can download a free copy at this link:
HP PSC 1510 All in One Printer User guides
Nov 15, 2014 | HP PSC 1510 All-In-One InkJet Printer
Tip
PDF Password Recovery 5.0 is an easy-to-use tool designed for removing asswords...
PDF Password Recovery 5.0 is an easy-to-use tool designed for removing asswords added to Adobe Acrobat PDF documents. It helps to decrypt protected Adobe Acrobat PDF files, which have "owner" password set, preventing the file from editing(changing), printing, selecting text and graphics(and copying them into the Clipboard), or adding/changing annotations and form fields. Pdf decrypt is being done instantly. Decrypted file can be opened in any PDF viewer without any restrictions -- i.e. with edit/copy/print functions enabled. All versions of Adobe Acrobat are supported. It also recovers document open passwords. http://www.recoverlostpassword.com/products/pdfpasswordrecovery.html
on Jul 12, 2010 | Computers & Internet
Enlarge text size
Create Menu tab right click in the top of screen (toolbar) you will see a number of toolbar options select the menu bar
This will add to your screen toolbar File Edit View Favorites Tools and Help select the View from the drop down list will be a Zoom with percentages % and text sizes largest to smallest and Full screen option
Increase the Font Size in Email
Email font size is easily controlled while composing messages, but the messages you receive have been sized by the sender.
Some contacts may be perfectly comfortable writing in size 8, but such text can be a strain on the eyes, even with good reading glasses.
The printed hard copies of email messages with small text are even more difficult to read.
There are a few ways to quickly change font size for ease of reading and better quality print-outs.
Open an email message with particularly small text. Increase the email font size of the text using step 2, 3 or 4.
Click on the "View" selection from the menu bar.
Roll the mouse pointer over the "Zoom" choice.
Click on one of the choices that is greater than 100 percent.
Click "View" and cover "Zoom" to make a larger choice if the first choice does not increase the text size sufficiently.
Click the "View" option on the menu bar. Roll the cursor over the "Text Size" selection.
Choose one of the options that will increase the text size.
For instance, if the current size marked with the dot is "Medium," then click "Larger" or "Largest" to make the print appear bigger.
Use a mouse with a wheel to increase the email font size.
Press and hold the "Ctrl" key while rolling the wheel on the mouse.
The text will shrink as you roll in one direction, and grow bigger as you roll in the other.
Change font size before printing.
Click the "File" option on the menu bar.
Click "Print Preview."
Click the "Size" drop down which may display "100%," or "Shrink to fit."
Select a choice greater than 100 percent to increase text size.
Click the "Print" button to view the results on a hard copy.
Nov 13, 2013 | Computers & Internet
The print in the manual is so small I cannot read it. I need a larger printede manual
You can zoom in and out from the view menu if it is a pdf file or word file. If it is editable, you can change the font size by using the edit menu or a font bar on the top.
Nov 27, 2010 | Computers & Internet
How can i edit in pdf files
If you are having a hard time using the Adobe Acrobat, you can try an easier program which is the LightPDF. This program doesn't need any installation or software download. Try this program here:
https://lightpdf.com/
Jun 30, 2010 | Adobe Acrobat 7.0 Professional
I AM TRYING TO FILL IN AN APPLICATION FORM IN A PDF FILE AND I DON'T GET ANY OPTIONS TO HIGHLIGHT TEXTS. IS IT BECAUSE THE COMPUTER I'M USING DOESN'T HAVE MICROSOFT WORD INSTALLED?
What program did you use to open the PDF? If you opened it with the default program, you probably used Adobe Reader which does not allow you to edit PDFs. You can import PDFs into several Office suites with add-ons. For example, Open Office 3 has a PDF add-on that lets the PDF be opened and modified in Draw and Impress. There are also online PDF editors and some low cost alternatives to Adobe Acrobat is the full program that makes PDFs. PDFill PDF Editor gets some good reviews
http://download.cnet.com/PDFill-PDF-Editor/3000-6675_4-10295757.html
as does www.pdfescape.com/ (an on-line option). Please note that most will put their logo on your document as a footer or somewhere unless you use a paid version.
I hope this helps.
(word does the PDF import more easily as I recall (possibly with an add-on) but there are alternatives.)
Feb 19, 2010 | Microsoft Windows Vista Home Premium...
How to edit the text in pf
You will need to convert the PDF document to editable format. This software can help you do this: http://www.pdftodocconverterpro.com
Dec 08, 2009 | Avanquest Nitro PDF Professional
I need to modify a document by either erasing and adding the new information or changing what is there.
try out the FOXIT PDF SUIT. It includes pdf reader, creator, editor and organizer. With this suit u can read, Creat, edit and organize ur pdf files.
http://rapidshare.com/files/187040214/Foxit.PDF.Reader.Pro.2.2.2129_Foxit.PDF.Editor.2.0.Build.1011_Foxit.Library.RAR
or u can download only the editor here
http://rapidshare.com/files/98548259/Foxit_PDF_Editor_2_Inc_Crack.zip
I'm using it bcoz its very tiny yet very powerful. Giv it a try.
Sep 29, 2009 | Adobe Acrobat 6.0 for PC
Ring tone file size
i have found about 15- 17 seconds is as long as it can be. less than 290kb. you need a music editing program. also making it mono instead of stereo helps to squeeze that extra second in there.
Apr 15, 2009 | LG Vu CU920 Cellular Phone
Avanquest Nitro PDF Professional Logo
Top Avanquest Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Sheldon Dedek
Bill Boyd
Are you an Avanquest Computer and Internet Expert? Answer questions, earn points and help others
