FOR oil leak issue check the following help links:---
Common Causes of Car Oil Leaks?
http://schematicsdiagram.blogspot.com/2011/12/common-causes-of-car-oil-leaks.html
Troubleshoot Car Oil leak?
http://schematicsdiagram.blogspot.com/2011/12/troubleshoot-car-oil-leak.html
Car oil leak?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leak.html
Car oil leaks from valve cover gasket?
http://schematicsdiagram.blogspot.com/2011/12/car-oil-leaks-from-valve-cover-gasket.html
Rear oil seal leaking?
http://schematicsdiagram.blogspot.com/2011/12/rear-oil-seal-leaking.html
leaking oil from oil pan?
http://howtobyme.blogspot.com/2011/11/kia-sportage-leaking-oil-from-oil-pan.html
leaking oil from timing cover?
http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
How to Check Differential
Oil Leaks and Replace Oil
http://schematicsdiagram.blogspot.com/2011/07/how-to-check-differential-oil-leaks-and.html
Oil leaks from air filter on ford?
http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
---------This
will help. Thanks.
Car oil leak?
Rear oil seal leaking?http://schematicsdiagram.blogspot.com/2011/12/rear-oil-seal-leaking.html
leaking oil from timing cover?http://technoanswers.blogspot.in/2012/02/toyota-corolla-leaking-oil-from-timing.html
How to Check Differential Oil Leaks and Replace Oil
Oil leaks from air filter on ford?http://technoanswers.blogspot.com/2012/01/oil-leaks-from-air-filter-on-ford.html
---------This will help. Thanks.
