Question about Sony Boom Box With CD Player & Cassette Recorder,CFD-S01CD Radio/Cassette/CD Boombox
I have a Sony boombox with cassette player and CD player on top. The tape deck works fine, but the CD player won't play. It sounds like it's engaging at first with the whirring sound, but then it just stops and nothing happens. When I lift the top, I can see that there was no movement of the disk.
SOURCE: Sony CFD-S300 boombox would not run CDs
what i would suggest you to do is get a q-tip and a little bit of rubbing alcohol on the tip and gently clean the lens let it dry
Posted on Jul 17, 2007
SOURCE: How to preset a radio station on Sony CFD-S200 Cassette/CD boombox
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
Posted on Jun 12, 2008
SOURCE: CD player says "no disk" when there is disk in player.
Get a CD Cleaner and check your electric current output to make sure it matches the voltage requirement.
If the CD Cleaner doesnt work, then replace your CD Lens
Posted on May 25, 2009
SOURCE: Call Customer Service Support 1-8O5-465-751O For Help CFD-S300 Sony Boombox lost power cord
What should be the secondary voltage be on 115 volt primary transformer off the power cord for the CFD-S300
Posted on Aug 23, 2010
Jan 17, 2014 | Sony Boom Box With CD Player & Cassette...
Apr 12, 2012 | Sony Boom Box With CD Player & Cassette...
Jun 12, 2011 | Sony Boom Box With CD Player & Cassette...
Dec 30, 2010 | Sony Boom Box With CD Player & Cassette...
Apr 30, 2010 | Sony Boom Box With CD Player & Cassette...
Apr 10, 2010 | Sony Boom Box With CD Player & Cassette...
Sep 14, 2009 | Sony Boom Box With CD Player & Cassette...
Mar 19, 2009 | Sony Boom Box With CD Player & Cassette...
Mar 16, 2009 | Sony Boom Box With CD Player & Cassette...
Jan 06, 2009 | Sony Boom Box With CD Player & Cassette...
205 people viewed this question
