Hi. my family was watching a movie yesterday and the tv was working fine then we went and got another movie and came back and turned it on and the screen didnt turn on and the was smoke coming out the back of the unit. im just wonder if we should get a new tv or get it repaired.
Brand: Astar 32 '' Tv HDTV
i dont the the model of it
SOURCE: 32"ASTAR problem
Please call 323-767-6030 and I will trying to help you as much as I can for the astar ltv-3201 tv.
SOURCE: I need a replacement circuit board for my Astar
The failures on these LCD's are due to defective capacitors in the power supply. There are about 23 capacitors that will need to be replaced to restore the LCD power supply functionality. Check the picture to see where the capacitors are located, the power supply on your LCD is not the same but similar to the one on the picture just the capacitors are place in a different order.
Let me know if you required further assistance.
SOURCE: I have a universal remote and it dont have codes
Astar is a no-name manufacturer - one that buys components from other manufacturers, puts the together cheaply and slaps a badge on the final product - so yes, the only way to get a code for it is to test the codes for the other brands.
SOURCE: My astar ltv 2701 27 inch hdtv tv started to smoke
I have a working motherboard from a broken screen LCD.
The smoke could have been from the capacitors in the power supply and not the main board. I would suggest to inspect the power supply as well for bulging or leaky capacitors that fail most of the time.
Let me know if you need further assistance.
SOURCE: My Astar 32" HDTV flat
I had a similar problem with my 42 in Philips LCD HDTV. Here was the problem.
My Power Supply Board had several bad capacitors. I opened my TV (warranty was expired of
course) and found four bulged capacitors.
Many electronics companies were sold capacitors that failed in 2-5 years
instead of 10-20. The capacitors fail
prematurely due to a lack of preservatives. Unfortunately, they were installed in all
sorts of devices and cause a wide range of failure problems. Here are some options for you. 1. Have it fixed by a professional 2. Open your TV and find PSB. Check
for faulty caps. If you find some (bulged
or leaking) bad caps replace the entire board. 3. Remove and then replace individual faulty caps. This takes some soldering skill. Caps are inexpensive and if you can take care of it yourself
it will save you hundreds. I have a tip/tutorial
on this site that may also help. It
gives step by step instructions for replacing caps on PSB #715t2432-2. If this is your board you are in luck. It's
called: Fixing the Philips Turns/shuts off on its own problem. Hope this helps and Good luck.
Kaufman605
