2000 Chevrolet Venture Logo
Posted on Jul 31, 2010
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Radio/cd player went dead. Tried replacing fuses
Radio/cd player went dead. Tried replacing fuses ... no good. Took out from dash to put in another and plugs are different with many extra wires. Can I get a wiring diagram?
Do I just cut the wires from dash and splice onto new ones?
Robert Billyard
Level 2:
Sergeant:
Champion:
  • Expert 277 Answers
  • Posted on Jul 31, 2010
Robert Billyard
Expert
Level 2:
Sergeant:
Champion:
Answers
277
Questions
0
Helped
68859
Points
750
Where you bought the new radio.. they should have asked if you need a Auto adapter.
So if you put this radio in a GM, you get a GM adapter
If it was a Toyota, then a Toyota Adapter
These adapter take away all the trouble of finding the right wires because they are prewired for the vehicle you want to install
Anonymous
Level 3:
  • Master 432 Answers
Anonymous
Master
Level 3:
Answers
432
Questions
0
Helped
152482
Points
1482
Do NOT Cut and Splice. Your local parts store sells an aftermarket radio plug in which connects to your factory harness and then you can splice in your radio into the new connectors ends that are labeled for what they go to.
1helpful
I have a 1999 Subaru Forester. The battery went dead after many ,many years. I replaced the battery. Upon connecting the new battery, the car alarm went off. I disconnected the battery from its negative...
Most all aftermarket radios have their own fuse next to the wiring harness plug. Depending on the brand, it may only take a few minutes to pull the radio out of it's sleeve to check for the fuse. Usually, you can pop off the trim ring to see what you are working with.
My dashboard went dead
sounds like a wire is not right and you blew a fuse
2helpful
3answers
I have a honda odyssey 2001 the light of the panel are not workinkg all the rest of the lights are working i check the fuse and are ok only i did was change the radio and install a new one but did not...
I'm guessing you're talking about the dash light aound the radio. The dash lights around the radio share the same fuse with all the other lights that come on when you turn the parking light on. If the other light are working then your fuses are fine. What i think might have happen was when you took the dash cover off, the bulbs behind it might had burn out. You might want to try new bulbs.
good luck
1helpful
2answers
My Radio and clock screen has went blank volume and controls do not work the clock does not work the radio plays and CD plays but screen is dead. 2001 525I BMW
it sounds like the Multi information display has failed (MID). It is the long display with all the radio controls on it. If you want to find a known good part they are really easy to swap out. Just remove the radio knob and if you look down in there, there is a place to put a T10 (i think maybe bigger or smaller) torx T10 screwdriver.if you turn it while pulling back slightly on the screwdriver it should come right out. It usually is the component that fails but as always you may want to check your fuses.
2helpful
Wiring for radio 1993 toyota corolla
You likely blew a fuse for your lights. Here is a wiring diagram for the original radio.
1987 Volkswagen Golf - tach light out, no power to radio/CD player
could be just a blown bulb for the tachometer.check the wiring behind the radio .you may have to get special tools to remove the radio in any car parts/stereo store
1helpful
2answers
Radio doesn't work blew a fuse
radio and clock doesn't work.  Is it the fuse?
Top Chevrolet Experts
ZJ Limited
ZJ Limited
john h
Thomas Perkins
Thomas Perkins
Are you a Chevrolet Expert? Answer questions, earn points and help others
