Question about KDS K717s 17" LCD Monitor
Display flickers, no image is displayed, buzzes at same time it flickers. tried it on multiple computers, same thing
  • 732 Answers
Jglendenning, If not into soldering irons, solder, meters, and electronic repair of "switch-mode-power-supplys/cold-cathode-fluorescent-lamp ballast-circuits" then trade for new unit! Retrevo .com lists K717s as time to retire unit. Before you do anything check out the longer and more useful video clips at YOUTUBE that deal with "lcd monitor disassembly" and "lcd monitor repair" FYI so you at least know what is inside a typical desktop CCFL back-lit LCD monitor. 99% use same basic design and principle of operation no matter what brand of unit you have or will purchase in future!!! Hope this helped some. 12fixlouie
Posted on Jul 27, 2010
Elmo projector
sounds like you did not setup image screen.
Start
control panel
display
change display settings
multiple displays --- extend displays
detect - will show 1 &2 on each screen
apply
Apr 23, 2013 | Printronix T4M Dt/Tt 4-Inch 203 Dpi Rfid...
Erratic display
So your Gateway is brand new or a refurb?
Aug 02, 2008 | Computers & Internet
I can't change my display image in yahoo messenger, if you are going to check it through detector/scanner, the display image shown was the old one iv used. but during chat, its totally black screen for...
To change your display image your computer needs to communicate with the Yahoo! servers. Sometimes this takes a longer time than usual. Make sure the source file you are using is not too big and you select it from the images list multiple times before pressing ok. Be patient, it's just temporary.
Mar 01, 2011 | Yahoo Messenger
Let's see if there is really a diagnostic expert out there for this... 1996 Plymouth Voyager 3.3L engine with 165,000 miles. I'm having intermittent starting problems. I can drive for weeks and no...
The way to approach this sreies of issues is to first remove the remote start/alarm from the equation and restore the vans electrical system back to original. From there, if it persists, we can do more trouble shooting. Let me know and I can walk you through the process. This is definately a problem that does require a diagnostician. Thank you for the level of detail you provided!
Mar 19, 2010 | 1996 Plymouth Voyager
W2753v screen flicker - refresh
Hi
What causes monitor screen to flicker?
Answer
keep electronics away from your computer. Mobie phones etc. can distort the image shown on the screen for periods of time, usually when a text or call is coming through.
Answer
A nearby device can cause stray magnetic fields that will cause the display to be affected.
A problem inside the monitor will cause the display to have problems.
If somebody turns on their monitor nearby, the monitor's degaussing when it starts up will cause your monitor to dance wildly for a moment or two.
Answer well one major cause can be the weakness of the electron gun that fire electrons on the silicon plate (pixels) that produces image on the screen so there must be some problem in electron gun in my view
Jan 29, 2010 | Computers & Internet
Erratic display
it sounds like a blown cap.. you can replace it if you know how to soder
Jun 11, 2008 | Gateway FPD1960 19" Flat Panel LCD Monitor
Multiple screen coming up in black and white also flickering on and off
I have a logitech quickcam E3500
I have 4 black & white images
I tried downloading older and newer versions of the software, no joy.
From the logitech site, I found this fix:
Go to Start>Run, type "dxdiag", wait for the application to show, then go to the "Display" tab and disable Direct3D acceleration or Directdraw acceleration. Exit. That's all.
I tried it and it works a treat.
May 16, 2008 | Logitech QuickCam Pro 5000 Webcam
TV has multiple images and flickers, images are not centered and different sizes? What is wrong?
Multiple image is usually a result of transmission problem. The signal from your local station gets transmitted two ways, by tower and cable. If the tv receives them both at seperate times it will create an overlap or shadow effect. I would try a small power booster on it, if not a service man may have to adjust the internal circuits.
Mar 07, 2008 | Zenith B32A24Z 32" TV
KDS K717s 17" LCD Monitor Logo
112 people viewed this question
Top KDS Computers & Internet Experts
Thomas F. Schneider
Siul Oyaratgam
Marvin
Marvin
Are you a KDS Computer and Internet Expert? Answer questions, earn points and help others
