SVA VR 17S monitor speakers not working in Windows 7 professional but the dual monitors are.
SOURCE: Cant find anywhere to download my driver
they may be no drivers for it, windows install is like a plug and play monitor
good luck to you
SOURCE: No display under 1024x768
I have the same problem with 800x600. I've found that by setting the refresh rate to 56 Hz, I can get the games to play. For instance Age-Of-Empires II only works with this method. My old monitor worked fine, and this works at 1280x1024.
SOURCE: i have a sva VR-17S monitor and i am trying to use
Normally you don't need a driver for a monitor, any screen resolution adjustments is done by the Control Panel - Display - Settings.
SOURCE: monitor comes on, then goes blank
it an error on main board, check for dry joints, resoldering, and leaky capacitors..check out
SOURCE: Where can I buy a power cable for a SVA Model
hello,
We carry the power cords on our web site at:
www.ccl-la.com
I hope this helps, if so please rate our solution.
Buddy
Corporate Computer
www.ccl-la.com
