Computers & Internet Logo
Posted on Jul 27, 2010
I am getting an error when I am trying to run my performance schedule in Rational Performance Tester, this is what the error looks like: IWAT0005E The host localhost not found. Any solutions on how to get past this?
I AM LOOKING FOR A USER MANUAL FOR A KAL EQUIPMENT T-141 GENERATOR TESTER please?
Question edited for clarity. Manuel is a Spanish man's name.
Not available because it pre-dates the Internet. Try KAL Tech direct.
T-141 Kal-Reg Regulator - Generator Tester, more than just another Volt-Ammeter. Performs many tests. Especially useful on inboards where dependable electrical performance is vital.
https://www.google.com/search?q=KAL+EQUIPMENT+T-141+GENERATOR+TESTER+manual
4answers
Error code 51 on Rational combo master plus. Changed battery but error 51 still displayed, any advice ?
Error 51 I perform cleaning the steam generator and all source of water and I change battery also but still error is appearing to please give me solution
Error code x854e
A scheduled maintenance is required to maintain the printer's performance. To do this, you need to install the proper maintenance kit.
2helpful
On a Chevy Hhr has p0014 code what needs repaired?
P0014 Camshaft position B over advance,or system performance bank 1.Clear the code,This appeared from either logic or rational.Camshaft postion usually appear on vehicle that are not in oil maintaince,this sensor has a tendency to get sluge built in it.This also appear when driver run the fuel very low,clear the code if it reappear its a hard code and a replacement or a service (clean it with gas or carb cleaner)it. is the solution
Hello my acer laptop is giving a message disk error hit alt ctr del for start up i do that but the screen stays black with a with small white blink - in the left hand upper corner
How to run Chkdsk loadTOCNode(2, 'moreinformation'); Notes
  • Chkdsk requires exclusive access to a volume when it runs. Therefore, if one or more of the files are open on the disk that you want to check, Chkdsk displays a prompt asking if you want schedule the disk check for the next time that you restart your computer.
  • Chkdsk might take a long time to run, depending on the number of files and folders, the size of the volume, disk performance, and available system resources, such as processor and memory.
  • Chkdsk might not accurately report information in read-only mode.
How to run Chkdsk at the command prompt loadTOCNode(3, 'moreinformation');
  1. Click Start, and then click Run.
  2. In Open, type cmd, and then press ENTER.
  3. Use one of the following procedures:
    • To run Chkdsk in read-only mode, at the command prompt, type chkdsk, and then press ENTER.
    • To repair errors without scanning the volume for bad sectors, at the command prompt, type chkdsk volume:/f, and then press ENTER.
      Note If one or more of the files on the hard disk are open, you will receive the following message: Chkdsk cannot run because the volume is in use by another process. Would you like to schedule this volume to be checked the next time the system restarts? (Y/N)Type Y, and then press ENTER to schedule the disk check, and then restart your computer to start the disk check.
    • To repair errors, locate bad sectors, and recover readable information, at the command prompt, type chkdsk volume:/r, and then press ENTER.
How to run Chkdsk from My Computer or from Windows Explorer loadTOCNode(3, 'moreinformation');
  1. Double-click My Computer, and then right-click the hard disk that you want to check.
  2. Click Properties, and then click Tools.
  3. Under Error-checking, click Check Now. A dialog box that shows the Check disk options is displayed,
  4. Use one of the following procedures:
    • To run Chkdsk in read-only mode, click Start.
    • To repair errors without scanning the volume for bad sectors, select the Automatically fix file system errors check box, and then click Start.
    • To repair errors, locate bad sectors, and recover readable information, select the Scan for and attempt recovery of bad sectors check box, and then click Start.
    Note If one or more of the files on the hard disk are open, you will receive the following message: The disk check could not be performed because the disk check utility needs exclusive access to some Windows files on the disk. These files can be accessed by restarting Windows. Do you want to schedule the disk check to occur the next time you restart the computer?Click Yes to schedule the disk check, and then restart your computer to start the disk check.
The following table lists the exit codes that Chkdsk reports after it has finished:
Collapse this tableExpand this table Exit code Description 0 No errors were found. 1 Errors were found and fixed. 2 Disk cleanup, such as garbage collection, was performed, or cleanup was not performed because /f was not specified. 3 Could not check the disk, errors could not be fixed, or errors were not fixed because /f was not specified.
courtesy of Microsoft.com
180,000 mile scheduled service
looking at my repair manual....the ford expedition only goes to a 60,000 mile schedule. so my input would be that the dealer will run a computer check which is $95 minimum and go from there. They will also run a drivetrain check and performance check. they will probably check for leaks, serpentine belt wear, front end and brake issues etc..basically everything and anything you ask for. i usually do all my own preventative maintenance. if they try to tell you something is wrong and you have not had any problems i would get a second opinion from a reputable garage before i would let the clowns start dismantling your vehicle.
1helpful
2answers
System Slowdown
You may not like the advice I am about to give but in my honest opinion either got to windows XP or wait for windows 7 due anytime.
Other than that you may wish to use add remove programs to remove any that you no longer use.
Remove any un wanted or in many cases un-needed tool-bars.
A good clean up may help you out considerably.
Depending on how much ram you already have then maybe extra ram would also be of benefit.
Vista is a known resource hog I have yet to actually recommend it to anyone and still advise people to stick to XP.
As a Microsoft beta tester I can however recommend Windows 7.
It does make Vista look slow and anyone who has used vista will notice the difference in speed but not too much in use.
It is what Vista should have been.
Top IBM Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
ExpressFiX
ExpressFiX
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
