Sanyo DS31590 31" TV Logo
Question about Sanyo DS31590 31" TV
Picture will suddenly get horizontal lines then may only get a bright horizontal line in the middle of the screen. I can rap the top of the set and the problem may go away, but it returns again at a later time. The TV is 9.5 yrs old. Sanyo Model DS31590, Chassis 31590-05
Posted by farlop65 on
Francisco Mauricio G
    Genius:
  • Sanyo Master
  • 1,551 Answers
Maybe you´ve cracked solder joints on the vertical Ic and need to resolder it
Posted on Jul 27, 2010
  • daniel timmons Aug 17, 2011
    wondering if this fixed the problem mine is doing same thing
2helpful
Screen suddenly has only a thin bright middle
If it has a white line in the middle running left to right the problem is in the vertical circuit.
This can come with age as solder connections (this is the most common cause) come loose or break at the chip in that circuit.
Much of the time with set on a good hard rap on the top or side and the line will try to open and return a full picture.
Someone who can get to it and can solder can fix that---the chip will usually have 7-13 pins and be mounted on a metal plate that is fairly small(it keeps the part cool)---fixed a lot in less than ten minutes.
You will have to open the set, locate the chip(usually a location number on top of board by it will be something like IC301 or 401).
Most of the chips will have a generic number on them a LA------ or such. You will have to remove the board to look at the bottom where the chip solders in.
I attach a photo of a typical chip.
Let me know if questions
Panasonic omnivision horizontal
If you have a white line on screen---middle that runs left to right it is a vertical circuit problem.
This can be a easy repair: The set uses a chip---usually 7-13 pins in a straight line package-----a lot of these sets the solder from heat breaks loose and all that is needed is to resolder the pins on that chip.
A hint: usually a good solid rap on the top or side will in this case try to make the picture open up.
You need to be able to get to the part and solder.
use the make a comment button if you have questions or need more help.
5helpful
3answers
TV: bright line across black screen for several hours.
vertical output ic needs to be resoldered. careful leaving that bright line displayed on the screen as this will cause a permanent phosphor burn into the tube. this can not be corrected once burned unless you replace the tube. mch
Horizontal line on screen
The most common problem would be a bad solder joint on the vertical drive IC. It could also be a bad solder joint on the flyback transformer, as it supplies voltage to the vert. stages. If you disassemble the set, please be careful not to get shocked. Discharge the high voltage stages as a precaution.
Geno
2answers
Picture/image problem
Bad solder connection in the horizontal pincussion circuit.have someone resolder.God luck.4tune
White horizontal line down middle of TV screen
caution whenever you see horizontal line please reduce brightness of your tv for safety of crt. your problem in vertical section only mostly due to loose contact in connector,print or loose components.
1helpful
3answers
I have a thin bright white line,horizontal,no picture
i have panasonic sophia tv 29" i have white horizontal line on middle of screen i know i have to solder ic but where is the ic located on main circuit board. thankx
Top Sanyo Televison & Video Experts
Jaime Hernandez
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
