Question about Brother IntelliFAX 4100 Laser Fax
Gray copies Have a Brother intellifax 4100 just changed drum, still saying change drum and copies are coming out gray.
Posted by nicole490 on
Igor Studennikoff
    Habit-Forming:
  • 145 Answers
Most likely you do not reset the drum. In this case, a new drum unit serves as the currents in the old, respectively, due to lack of charge is a problem with a gray background. Information on how to reset the imaging drum is open and is the official website of the manufacturer.
Posted on Jul 27, 2010
We can't find the manual for our Intellifax 4100 could you help me it is asking to clean the drum?
Most probably it is saying "Change the Drum." This is because the manufacturers have entered an arbitrary number of cycles as a reminder for you to buy a new drum. You can ignore this until the copy quality becomes too bad to read, then replace the drum.
Oct 05, 2010 | Brother IntelliFAX 4100 Laser Fax
We are getting black faxes and dark grey copies
I recommend to clean out an optics. Take apart a cartridge and well blow through, clean the rollers and contacts.
Jan 14, 2010 | Brother IntelliFAX 4100 Laser Fax
How do i reset the message change drum soon on
Press Clear.
8 Press 1 and when the LCD shows ACCEPTED,
and then close the front cover.
Jun 05, 2009 | Brother IntelliFAX 4100 Laser Fax
Print Quality Problem with Brother 2820 Fax
sounds like you are using generic drum and toner. try OEM (brother brand). you say copies are coming out completely gray. try printing an internal report from the control panel. if that is gray or received faxes are gray, then the problem is not in your scanner area, and i would wager you are using "generic" supplies.
hth,
razors
Apr 10, 2009 | Brother IntelliFax-2820 Laser Fax
We have the intellifax 4100. It keeps telling us
Hi Sandy58 this is the fix. all you have to do is: open the front cover (leave it open) and press the clear button then it will ask you NEW DRUM AND YOU ENTER 1 FOR YES and that's it good luck.
any other question please email me,
thank you.
Mar 19, 2009 | Brother IntelliFAX 4100 Laser Fax
Change drum soon
Instructions are in the box that the new drum comes in.
Jan 13, 2009 | Brother IntelliFAX 4100 Laser Fax
Have you tried a new toner cartridge?
Oct 27, 2008 | Brother IntelliFAX 4100 Laser Fax
Drum intellifax 4100 Brother
some faxes will shut down if it senses toner low/out
you must replace and maybe reset counter
Jul 30, 2008 | Brother IntelliFAX 4100 Laser Fax
open front cover, press "clear" and 1, that will clear the change drum soon error
Jan 14, 2008 | Brother IntelliFax-2820 Laser Fax
Brother IntelliFAX 4100 Laser Fax Logo
236 people viewed this question
CheckitRight
CheckitRight
James Cagle
James Cagle
Norman  J Weimar Jr
Norman J Weimar Jr
