Question about NEC Dterm DTP 16D-1 Corded Phone
I am trying to change the name displayed on my nec i-series phone. How do i do this?
Anonymous
    New Friend:
How change the greeting on the NEC Dterm80
telephone system?
Posted on Mar 26, 2011
Anonymous
    New Friend:
    Problem Solver:
  • 4 Answers
1. + 800 + Dial your
extension number + Enter name (see the
chart above).
Your name can be up to 12 digits long.
2. .
You hear confirmation beeps.
3. to hang up.
This feature may be restricted for
some users.
Posted on Aug 12, 2010
Anonymous
    New Friend:
  • 4 Answers
Assuming you are not an NEC trained Tech and your system is on a IPKII, You will best served by acquiring the IPKII Instalation manual and the Feature and services Manual.
This is not the kind of simple change that the average end user should attempt although I would agree that it is a feature that should have been made availiable to the average user because of occasional movement in
any office environment.
Posted on Jul 27, 2010
5 Related Answers
Anonymous
SOURCE: Adding/Changing Name to NEC multi-line phone
On an NEC Elite you must enter system programming to change the name of the extensions. Unless you have a PC connection to the system this is somewhat complicated. If you would like me to step you through the system programming, please contact me @ 850-326-0394.
Posted on May 23, 2007
Anonymous
SOURCE: NEC Dterm80 Name change
OK, I got this from somewhere else. But anyways, pick up the phone and dial 700, then dial the extension number, then finally you can punch in the name like you would doing a text message. When you're done, hit Hold, hang up, and hit Speaker twice.
Posted on Sep 05, 2008
Anonymous
SOURCE: NEC dterm series II phones-name desplay
This works on the series E phones. It may or may not work on the series II.
  1. Press the Speaker key (do not use the handset).
  2. Dial the Name Assignment access code and wait for the special dial tone.
  3. Using the key pad spell the name. Press each number until the letter appears.
  4. When the correct letter is displayed Press the HOLD key. Pressing the HOLD key will lock the letter in place and advance to the next position.
  5. Repeat steps 3 and 4 continue to spell the name.
Pressing the TRANSFER key will change the current letter to lower case.
Example to enter the name “Pat” press:
77 HOLD 22 TRANSFER HOLD 88 TRANSFER HOLD
Posted on Sep 23, 2008
Anonymous
  • 3 Answers
SOURCE: Trying to change the name on the display on the phone
Dial 700>dial your ext #>enter name>press Hold & press Speaker
Posted on Apr 06, 2009
Anonymous
SOURCE: Name Display NEC DTerm Series i
It is changed via MAT or MOC programming. See you PABX Technician.
Posted on Jul 29, 2009
How do I change the display name on a NEC ETW-16DC-1 display phone that is on an Electra Professional Level II phone system?
You will probably need to add the extension name via system programming. The following installation manual for the NEC Professional Level ll phone system may help (copy & paste)
http://pdf.textfiles.com/manuals/TELECOM-A-E/Electra%20Professional%20Level%20III%20Install%20Manual.pdf
Jun 14, 2018 | NEC Lands Phones
How do i change the extension name on the display of NEC Dterm Series i?
Which NEC system is the Dterm Series i connected to? Normally you change the ext name in system programming, but I need to know which system it is.
Oct 14, 2016 | NEC Lands Phones
How to Change Display Name
There is no option for it on your extension because your "class of service" is not set for it. Probably the only extension set for name change is 301 if the default configuration was not changed.
Mar 25, 2017 | NEC DSX 22 Corded Phone
Display name not mine, how do i change it?
Here's a link to the individual steps:
http://www.telephonesystemsdirect.com/necdsx/nec-dsx-knowledge-base/changing-the-name-on-a-nec-dsx-22b-display-tel/
Dec 16, 2013 | NEC DSX 22 Corded Phone
How to Change Time on NEC Dterm Series E phone
Press the "Speaker" button and enter 728 on the key pad. Then enter the correct time.
Mar 14, 2012 | NEC Electra Elite DTU 16D-2 Corded Phone
How to change name display
There is no user programmable way to change the name display on your phone. On NEC systems, you have to go into programming mode and access the memory block for extension names. Sorry.
Jun 01, 2011 | NEC DTH-8D-1 Corded Phone
Mar 27, 2009 | Lands Phones
Feb 13, 2009 | NEC Dterm DTP 16D-1 Corded Phone
Apr 16, 2008 | NEC Dterm DTP-2DT-1 Phone
May 21, 2007 | NEC Electra Elite 32D-1 Corded Phone
NEC Dterm DTP 16D-1 Corded Phone Logo
1,411 people viewed this question
Top NEC Lands Phones Experts
Zhareese
ray gallant
Tom Chichester
Are you a NEC Lands Phone Expert? Answer questions, earn points and help others
