Zanussi ZWF1420W Front Load Washer Logo
Posted on Jul 26, 2010
Drum fills withe water when machine is not in use
Zanussi aquacycle 1000 drum fills withe water when machine is not in use
Anonymous
Level 1:
Champion:
  • Contributor 274 Answers
  • Posted on Jul 26, 2010
Anonymous
Contributor
Level 1:
Champion:
Answers
274
Questions
0
Helped
66908
Points
12
Can you turn off water to machine? The water seleniod needs to be replaced this lets water in the switch sounds like it's stuck open.
Access motor belt zanussi aquacycle 1000
There is usually a hatch at the back of the washing machine.
1helpful
Zanussi F1045W Front Load
indicated low water pressure from your external supply or blocked filters in the fill hose. turn water off, remove hose and check filter in end of hose - it is just a bit of gauze. also look into the valve and clean out if needed
Zanussi aquacycle 1200 smells coming from between the drum and casing.Suspect it is caused by a build up of slime etc.
1. Set the washing machine on the highest water level, temperature on hot and the wash cycle to normal.
2. Fill a gallon jug with hot tap water. Once the cycle begins, let it run for a minute or two, then stop the cycle, open the lid and slowly add the gallon of hot tap water. Don't overfill — you just want to raise the water level so that it is able to reach and clean the inside top rim.
3. Add 2 to 4 cups of household chlorine bleach and restart the cycle. In a couple of minutes, stop it again and just let it sit for at least 30 minutes. Afterward, let the cycle finish, and open the lid to air out the inside.
I got it from this link: http://answers.yahoo.com/question/index?qid=20060827101905AANuYg4
and here:
http://deseretnews.com/dn/view/0,1249,600124768,00.html
4helpful
2answers
Zanussi aquacycle 1000 washing machine spin problem
this is possible due to a bearing collapse or bearing spider broken. this causes drum pulley to be out of line and the belt comes off
Zanussi washing machine wont spin
check the drain hole when you start the machine if the water is coming back out , if yes that means your dump valve is bad.
Zanussi aquacycle 1000 xc washer
faulty fill valve. or tap not switched on correctly if it has the blue tap remove the top of the tap and use pliers to switch it on
Top Zanussi Washing Machines Experts
ZJ Limited
ZJ Limited
Kolbrun...
Mike Cairns
Mike Cairns
Are you a Zanussi Washing Machine Expert? Answer questions, earn points and help others
