Question about Cuisinart CPM-800 Popcorn Maker
I have a model CPM-800BKWS popcorn maker and have lost the directions. It has been in storage for several years. I want to try making popcorn again but I don't have any directions. Can you help me? Where can I print out a manual? Where can I get basic instruction on how to use the popcorn maker?I did google for help but did not find the answer
Posted by lindabetty on
Stephen Yanowich
  • 396 Answers
Click below for the link and download the manual.http://www.cuisinart.com/discontinued/specialty_appliances/cpm-800.html
Posted on Jul 26, 2010
Instruction manual for Cuisinart Easy Pop popcorn maker Model CPM-900
Hello, Sandra -
Even though the Cuisinart Easy Pop Popcorn Maker, Model CPM-900 is discontinued and no longer manufactured by Cuisinart, I was able to find the user manual on the Cuisinart web site.
All I did was use my favorite search engine, Google, and enter this search phrase:
Cuisinart CPM-900
The first search result brought me to this web page:
https://www.cuisinart.com/discontinued/popcorn_makers/cpm-900/
From that page, I was able to click on the Manual link, near the top center of the page, and end up here:
https://www.cuisinart.com/share/pdf/manuals/cpm-900.pdf
Note: The manual is in PDF format, so you will need Adobe Acrobat Reader software (free.)
Best wishes.
May 21, 2018 | Cuisinart Kitchen Appliances - Others
Base doesn't get hot
You cannot repair home model poppers, return to store or replace.
Feb 10, 2014 | Cuisinart CPM-900 EasyPop Popcorn Maker...
I need to order a kettle for my Old Fashion Movie Time Model CCP-509 and I don't know what size kettle it is and where to order it from??
Nostalgia Electrics CCP-509 Movie Time Popcorn Maker
  • Now for the finishing touch -- a full sized popcorn cart that makes delicious, old fashioned, movie house popcorn. The design is nostalgic, but the features are very modern.
  • Tempered glass window.
  • Large stainless 4 oz steel kettle with built in stirring system.
  • Warming light.
  • Kernel catcher.
  • Supplies compartment.
  • Safety Electrics, and easy to clean design.
  • Popcorn never tasted so good at home.
  • Makes up to 1.5 Gallons of popcorn per batch. 4 oz Kettle.
  • Storage compartment in base of unit.
  • Dimensions: 16"L x 19"W x 60"H
Feb 04, 2011 | Nostalgia Electrics Helman Group CCP-509...
We have lost the directions. How do we make the popcorn/
If you have a 4oz kettle it takes 1 TBSP oil and 1/2 cup popping corn. If you need a new manual you can get it at http://www.nostalgiaelectrics.com/default.asp?a=service
Oct 16, 2009 | Bond Helman Old-Fashioned Movie Time...
One of the side handles broke and it will no longer lock down.
Go to cuisinart.com> LOoks like you will have to replace the base or the top. Under $25 each.
Aug 05, 2009 | Cuisinart CPM-800 Popcorn Maker
Broken plastic window
I have found the plastic window online at the Back to Basic Company web site.
http://www.focuselectrics.com
I ordered two. They were $2.00 each plus shipping.
I navigated to the parts area, to the popcorn. Here is the link. http://www.focuselectrics.com/catalog.cfm?dest=itempg&itemid=3678&secid=53&linkon=category&linkid=90
Hope this helps.
Feb 17, 2009 | Back to Basics Popcorn Popper (PC6)...
Doesn't heat
The heating element has burnt out or is defective! return for repair or if you have recipt a new one!
Jan 25, 2009 | Cuisinart CPM-900 Popcorn Maker
Popping plate not heating up
Remember the strirring rod connects to the motor, but the heating element connects via the two prongs in the rear, so the motor can run without the heating element turned on (turn on the base without the plate on...the motor runs fine). Try reattaching the plate...it needs a good connection to the connectors in the back. It should heat up pretty quickly. Also, if you put the heating pad in the dishwasher, make sure it is dry and that the contacts aren't tarnished.
I'm certain over time the contacts will get loose and the popper will stop working, but our is going fine after a year.
Also, be careful not to drop the base...lots of cheap, hard plastic that will break and rattle around.
Mar 01, 2008 | Cuisinart CPM-800 Popcorn Maker
Cuisinart CPM-800 Popcorn Maker Logo
174 people viewed this question
Top Cuisinart Kitchen Appliances - Others Experts
ThaMp3Doctor
ThaMp3Doctor
Irene Tulloch
Tom Chichester
Are you a Cuisinart Kitchen Appliances - Other Expert? Answer questions, earn points and help others
