I want musket bear-paw 12cu+ install on my window xp 2005
I lost my driver for Mustek BearPaw 1200CU and i downloaded microwhiz but it requires me to buy a product afterwards. I dont want to buy anything. I already bought a scanner. I only want a driver ! Pls help
SOURCE: I want Vista driver for my scanner Mustek BearPaw
Thank's to Google I visited http://www.mustek.de/eng_/html/treiber/scanner/bp4800tapro2.htm
and found what needed.
Thank's for your interest
SOURCE: mustek 1200CU vista driver
If you use a live CD of Linux, it is possible then to get this scanner to work, saving the files in a directory accessible to Windows, then exit Linux and you can access the scanned information from windows, this is the only work around.
SOURCE: no drivers found for mustek bearpaw 4800ta pro
well, you said that it has xp drivers, so just use those..... If you meant vista, then No....
SOURCE: Mustek Bearpaw 4800ta proII need Vista/Windows 7 driver
Download from HERE (33.7 MB) or HERE (79MB)
These drivers are for Vista.
If you need them for Se7en - in setup.exe file properties point "Install in Vista compatibility". My Se7en accepted...
