I have a Sharp Comfort Touch Air Conditioner which keeps shutting down leaving "E-1" remaining. To what does that refer? what is wrong?
This is a reminder to clean the air filter. It happens every 720 hours of operation. Here are the steps to get it back up and running:
1. Power down the air conditioner using the "power" button on the front panel.
2. Unplug the air conditioner from the wall socket.
3. Hold the front panel "power" button down and plug the air
conditioner in. Continue to hold the power button down as the machine goes through a brief test sequence (fan & compressor each come on briefly, etc). There is a "beep" sound at the end of the test sequence, and the machine will be off. At this point, you can release the power button.
4. Unplug the air conditioner.
5. Plug the air conditioner back in.
6. Congratulations! You should now be able to operate the air
conditioner normally for another 720 hours, but only if you followed the instructions above EXACTLY.
Display Codes:
E1-Automatic filter clean
reminder.
Turn the air conditioner OFF and
unplug it. NOTE: The air conditioner must be unplugged for the automatic
filter clean timer to reset.
Clean the filter. See the Care and Cleaning section in your use&care manual. After cleaning, replace the filter and plug the air conditioner back in.
