Question about Maytag Neptune FAV6800AW Top Load Washer
For the FAV6800a or FAV9800A the Motor Controller the p/n is 25001079 Sears Pardt direct Motor control
FAV6800A/FAV9800A Service Manual for reference. Sears Parts Direct for reference if you don’t have.
AppliancePartspros.com http://www.appliancepartspros.com/part_details.aspx?part_id=4033628
ApplianceZone.com http://appliancezone.com/SearchProducts.aspx?id=25001079.
Check to see if parts supplier will allow return if that is not the issue. I buy used from ebay owner used. Never had a failed purchased part to date but they are hard to find just can’t search by p/n.
What are your failure symptoms for the Motor Controller? Any error codes with the issue. I assume you have done some machine self checks which will not always point you to the failed subassembly. i.e. http://www.fixya.com/support/t2419091-maytag_neptune_top_load_fav6800aww_tub
Good Luck Rich
Posted on Jul 26, 2010
Hi
Its available for $213 and 219 with different dealers. Please check these links for more details from where to buy--
Maytag Neptune FAV6800 Control Board Link 1
Maytag Neptune FAV6800 Control Board Link 2
Please post back for any further assistance.
Daniel
Jan 11, 2016 | Maytag Neptune MAH5500B Front Load Washer
Aug 17, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Neptune TL Washer FAV6800AWW""
That is a repair sticky where I have DIY support for FAV6800A or FAV9800A Maytag TL's.
You do not need a lot of mechanical experience just some guidance if you wan to save your 1$K machine.
Aug 04, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Apr 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
If you want to DIY the issue Google "Sticky: Neptune TL Washer FAV6800AWW" you can get the Service Manual from that site to help you DIY the fix along with forum guidance.
I discuss the troubleshooting the Left Hand Lid Lock in that sticky.
I can't find my repair notes on this forum no Sticky and no Service Manual.......D*ick
Feb 27, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Google this ""Neptune TL Washer FAV6800AWW""
This is a sticky for the FAV6800A/FAV9800A washer DIY support. Go to the 5th post down in the Sticky and you will find a link for the Service Manual.
If you want to go further in troubleshooting and possibly a DIY fix just open a new thread in that DIY forum with Model number and Serial number. That info is found tag behind the console right back side as you face the machine console.
Feb 24, 2011 | Maytag Neptune FAV6800AW Top Load Washer
Oct 06, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Jun 29, 2009 | Maytag Neptune FAV6800AW Top Load Washer
Apr 15, 2009 | Maytag MAH6700AWW Neptune Front-Load...
Dec 31, 2007 | Maytag Neptune MAH5500B Front Load Washer
177 people viewed this question
