Question about GE JVM1790 1000 Watts Convection / Microwave Oven
THE START BUTTON WILL NOT START THE OVEN, WE HAVE GE-JVM1790
THE START BUTTON WILL NOT START THE OVEN, WE HAVE THIS OVEN SINCE 6 MONTHS, TRIED UNPLUGGING FOR 5 MINUTES, SAME PROBLEM , I CAN SET TIME , PUSH DIAL BUT NO STARTING?
    Habit-Forming:
    New Friend:
  • 23 Answers
The start button uses carbon pads and they could be worn out or not contacting properly you try and replace the control pads
Posted on Aug 02, 2010
Ge microwave jvm1740 start and clear/off button not working
Sounds like a bad keypad. You will need the full model number off the microwave to look up the correct control panel part number. Sometimes these type of parts can be really expensive & it may make more sense to replace the microwave depending on the age and condition.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/jeffrey_634abadf963e31e5
Sep 05, 2014 | GE Spacemaker JVM1740 Microwave Oven
I have a GE sensor microwave oven. Tried to heat food and sensor eror came on. Everything is running even the timer but no sound but the timer is running. Cant this be reset pls help
HELLO.
This is the solution to reset your microwave.
1 Pressing the clock button will display the time. You can also use this to know what time it is while cooking.
1. Set the clock by pressing the "Clock" button.
2. Turning the dial on the GE sensor microwave oven will display the hour of the day. Once you have found the correct hour, press the dial in.
3. Again, turn the dial to set the minutes of the day. When this is completed, you will need to press the dial in again on the GE sensor microwave oven.
4. When the time and minutes are set, turn the dial again for a.m. or p.m. Then you will need to press the dial in to save the settings.
5. Press the "Start" button to allow the clock to begin on the GE sensor microwave oven.
Thanks.
Sep 18, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
I have a GE Spacemaker XL1800, about six years old. It heats food fine, but there is a terrible grinding sound while it does so, for the entire time it is running. This has been going on for several...
Personally, I would replace the Microwave. It is bound to be below specification by now if it has been used quite a bit.
Then you will know you will be fine for a few years.
Dec 15, 2010 | GE XL1800 1100 Watts Microwave Oven
My keypad is also dead.
No, but as with all electronic items faulty ones typically show themselves up during the first few months of use.
You've probably just been one of the unlucky ones.
Sep 08, 2009 | GE Spacemaker JVM1540 Microwave Oven
Fan runs constantly and can't be turned off. Unplugging it for months doesn't help
Fan relay is stuck on or button is bad (assuming this is over the fan stove function you're referring to) if not same still applies.
Aug 06, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Replace Microwave Light
Apparently there's a flaw in the design. My light has gone out/ been changed roughly evry 9 months. No longer under warranty and cost to have someone come in and replace is outrageous. Light bulb is located on top of the oven. You need to remove the top to get at it. Looked fairly easy.
Jan 01, 2009 | GE Advantium 120 Convection/Microwave Oven
Microwave dead - what to do now?
Still under warranty so someone is coming to fix it free of charge...
Nov 09, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
GE JVM1790 1000 Watts Convection / Microwave Oven Logo
209 people viewed this question
Top GE Microwave Ovens Experts
Poppa Maddo
Poppa Maddo
William Miller
William Miller
Jimmy
Are you a GE Microwave Oven Expert? Answer questions, earn points and help others
