Mitsubishi ws55511 will not power on.after power outage.
I have unplugged the back, turned back on, hit reset button with pin, and gfeen light won't stop blinking... can't power on after reseting it.
Have done the trouble shooting...
dm need to be replaced?? who does this for residential? I live in Mass
Denise
SOURCE: Mitsubishi TV WS 65869 blinking Green Light
This is a common problem with Mitsubishi rear-projection TV's.
See my post at http://www.highdefforum.com/showthread.php?t=58189
or email me at [email protected]. I can send you the instructions I used to successfully repair my Mitsubishi WS-55613 which was doing the same thing....
SOURCE: Mitsubishi WD-62525 yellow blinking status light
Check that the lamp door is closed all the way. There is a saftey switch that closes from the door being on all the way. If not the status light will keep blinking. There is also a switch on the air filter door.
SOURCE: unplugged tv before storm, tv was running fine
2 possible problems--this set has a receiver box in the back(left side as you look from back) if it is gone the green led will never stop blinking---if you unplug the set and plug it back about 70 seconds later the led should stop blinking--this is boot up for that box----the only thing other than that will cause this trouble is if the reset button on the front of the set is bad--if you remove front speaker grill and unplug the one or two plugs that go from the front keyboard the set should still turn on with the original remote---then you can leave them disconnected and just use the remote---if the set still does not turn on---the receiver is bad--only way to get this part is remove the original receiver and send it out for rebuild--very expensive and usually not worth doing--the part is no longer available from Mitsubishi---and when it was it was about 800 dollars---a rebuild of your current unit will be about 300 dollars plus labor to remove and re-install -----if you have any questions or need more help---
[email protected]
If this is helpful I would appreciate a vote here from you.
Regards, Steve
SOURCE: Green Light on Mitsubishi WD-62525 keeps blinking
Fluke solution: Press and hold Menu+Enter on front of TV...
WD-62525: My Green Blinking Fix!!!
http://www.avsforum.com/avs-vb/showthread.php?s=eb9ba9017a86fd9993de5feb77ee5f25&p=17646001#post17646001
