Question about Yamaha RX-V1500 Receiver
(A) channel doesn't work and there is a hum in the subwoofer ???
Posted by tyco4550 on
ADRIAN
    Sergeant:
  • 313 Answers
Check ALL connections as this sounds like an open circuit. check cables to and from all units and speakers.
Posted on Jul 26, 2010
Why is there low humming in the receiver sub channel(only?)
Sounds like a shorted capacitor in the sub out circuit.
May 04, 2015 | RCA Audio Players & Recorders
Speakercraft v10 subwoofer not taking input signals
Does any other speakers work through the channels you are putting the subwoofer through? Reason i ask is could there be a fault with the channel you are using i.e AUX? is your subwoofer connected with Aux cables or is it a speaker cable? If aux cable is there a slight break in the cable?
Jan 04, 2014 | Audio Players & Recorders
Got a 4 channel amp but can only use 2 channels, dont know why//
Did you check the fuses on the amp. If one of them has blown, this will shut it down. You will also need to check to make sure your RCA cables from the unit aren't crimped. This could kill the signal. Have you swaped the RCA cables to see if the other side works. If so and it still doesn't, check thos fuses. If this still doesn't help, you may have internal problems with your amp. Hope this helps
Aug 19, 2011 | Car Audio & Video
Subwoofer will not produce sound. Connections are correct. I do hear a hum or a crackel as I pull the connection on and off. AVR-689 model
In order to ensure output to your subwoofer: make sure the subwoofer is connected to the subwoofer out of your amplifier and make sure that your amplifier/receiver is set to output multi channel sound
May 07, 2011 | Denon AVR-689 Receiver
I have atomic A-8 subwoofer and philips FR740 receiver. when i turn the amplifier and the subwoofer "on", the subwoofer starts to hum loudly and it is wery annoying. i made all the connections...
The symptom sounds like an open signal shield somewhere and the cable is acting like an antenna for airborne electrical noise.
Disconnect the RCA cable at the sub. Is it still humming? NO? Problem is external to it. YES? Internal. Broken ground somewhere.
Recheck all connections making sure to twist the RCA head as you install it so oxides will be worn off.
Consider what may have changed in the environment regarding electrical devices, motors, magnetic sources. Ensure signal and speaker wires as ar not running are as non-parallel to any power cords as practicable.
Apr 23, 2011 | Eltax Atomic A-8.2 Subwoofer
Mirage s8 subwoofer is emitting a constant hum
that is just the radio from the input,its normal
Jun 19, 2010 | Mirage Prestige S8 Subwoofer Speaker
My Sony model SS-MSP1 , SA-WMSP1 , AC120V , 60HZ , 50W hums.
If it hums on the audio side on all channels it might be the 60hz mains hum getting through. This is caused by the failure of the large Electrolytic capacitors in the power supply.
Another cause of hum (not in the audio) is the transformer. Also parts that hum should be replaced. If you can't pin down a huming part IE where it is. Then use a drinking straw as a stethoscope, by putting one end in your ear and the other over the PC board.
Feb 14, 2010 | Sony Audio Players & Recorders
Hum and left channel doesnt work
Are these new speakers? My sub hummed when I had it in plugged in to the wall outlet with a light switch connected. As for the speker not working maybe a wire is loose inside the speaker cabinet. If it was dropped or something.
Sep 25, 2007 | Boka 2000 Computer Speakers
Loud hum on subwoofer.
try another speaker on that channel if you get no sound or it hums then it is time to take your set to a tech your audio out put on that side is damage along with some caps.good luck.
Mar 30, 2007 | Polk Audio RT1000I Speaker
Yamaha RX-V1500 Receiver Logo
71 people viewed this question
Top Yamaha Audio Players & Recorders Experts
 Grubhead
Grubhead
Will
Level 1 Expert
Are you a Yamaha Audio Player and Recorder Expert? Answer questions, earn points and help others
