The problem is due to the rubber boot is been torn that is causing you the leak. You have to check the rubber boot for leaks by removing the clamp assembly that secures the rubber boot to the outer lip of the door opening. Peel off the rubber boot then inspect it for any holes where it may be leaking. The rubber boot in your washer can be accessed only when you remove the front panel. This requires the removal first of the top panel then the console. Also check your inlet hoses on the outside of machine, also check the connections inside the panel in back.
Thank you !!
