Most likely caused by a short, could be any were. start with the light assembleys remove it and clean any rusty or coroded spotspull all bulbs clean and or replace .auto parts stores sell an electrical parts wash about 9 to 14 $ . spray as needed let dry and put back together.if it still blows fuses its some ware in the wire s , could also be at the turn signal switch or the brake switch . you would have to get it to blow to figure out witch one it is and witch one it is not example put in new fuse then keep putting on the brakes if not blown then keep doin the turn signal then check to see if blown
